Question about Epson PhotoPC 3100Z Digital Camera
Manual Shutter Priority Settings
Is the only way you can use the 3100Z camera in manual shutter mode is in the LCD mode?? This is what I've been told by Epson, although there is nothing in the manual that indicates this. A related question: once you set the shutter option to a particular setting, you apparently lose these settings if you switch to viewfinder mode and then back. The crazy thing is, at least on my camera, the shutter speed defaults to 1/30!!!! Where is the logic in that? Most any picture taken at that setting will be blurred. If this is correct, does anyone have experience with any other comparably equipped digital cameras to advise if their manual shutter priority settings can be used through the LCD and not the viewfinder?? It's not just the waste of batteries but the inconvenience of taking pictures using the LCD.
  • 42 Answers
I've found a "trick" to keep the Shutter Priority Mode for viewing and composing with its Optical View-finder before.
However, after some years of time I have to recall it again before posting.
Posted on Feb 04, 2008
    Master:
  • 542 Answers
I like to switch to viewfinder mode to conserve the battery between shots. If using aperture priority, no problem; however, while using either shutter priority or manual mode, it defaults back to Auto exposure as you pass through the viewfinder mode. Seems an unusual thing for an electronic device to do, but it appears the software actually "resets" when in the VF mode. Maybe Bill Gates had something to do with the programming. One advantage of using the LCD is that the camera will advise you on the appropropriate aperture and shutter for your manual shot when you pre-press the shutter button. If you're a little low/high or slow/fast, you can make an adjustment before you lose that perfect shot. I admit I have found it to be annoying, but I do carry three sets of rechargeables (not that I've ever needed to get into the third set). I don't have any experience with other manual mode dc's, but unless all of these manufacturers went to Redmond, WA for their programming, I'd find it difficult to believe they're all like this.
Posted on Sep 13, 2005
    Master:
  • 542 Answers
Try the PROGRAM MODE-SPORTS setting. this will keep the shutter speed reletively high unless there is little light. Or use APERTURE PRIORITY MODE with an f2.0 to f2.8 to keep shutter speed high. If pictures were blurry when it went to AUTO then the light had to be low for the camera to select a low shutter speed. If using flash use forced or auto flash not slow sync. Also set ISO to 400 which is >>>. If inside use a larger external flash as the one on-camera is only good for about 10ft. if more than 10ft. away set focus to manual infinity so you don't have to wait for the camera to focus. Hope this helps.
SOURCE:
Why does my brand new Canon 6D freeze when shooting in RAW
The question in the title and the first sentence imply to me that you have confused manual mode and RAW format.
Title: "Why does my brand new Canon 6D freeze when shooting in RAWD freeze when shooting in RAW"
First sentence: "My brand new Canon 6D freezes when I try to shoot in manual."
Manual mode means you are responsible for all of the settings related to exposure (aperture, ISO, and shutterspeed). RAW is a specific file format to save the photo. They are independent of each other.
My guess is that in manual mode you have the shutterspeed set to the maximum of 30 seconds. The camera isn't going to automatically adjust it for you in manual mode. If you're new to DSLRs, start with Ae (Aperture priority) or Tv (Shutter priority). In Ae mode, you control the aperture and the camera will select the shutterspeed. In Tv mode, you select the shutterspeed and the camera selects the aperture for you. Start off with Auto ISO. This will help you learn what combinations of settings work well together.
Jun 25, 2013 | Canon EOS 6D DSLR Camera Body Only
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
How do I change the shutter speed on the Fuji S8000fd
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
May 27, 2010 | Fuji FinePix S8000fd Digital Camera
Shutter speed actomatic change
If you move from mode to mode, the camera will remember the settings from the last time you were in that mode and reset to them. This is handy if you are in shutter priority shooting sports at a high shutter speed, and then want to take a picture of something that's not moving fast, like the crowd. You just pop it into aperature priority with a remembered settings of a higher f stop.
I use this to shoot the scoreboard, which has a fairly slow refresh rate and usually comes up blank if I shoot it at a shutter speed higher than about 1/100.
Sep 02, 2009 | Nikon D300 Body Only Digital Camera
Slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Jun 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
3100Z - 25% Out of FOCUS!!!
I have notice a similar problem when using my 3100Z. I have found if I use Shutter priority mode and set the shutter speed to 1/60th to 1/125th that the problem is corrected. There are several reasons you are seeing motion blur. Most 35mm would set the shutter to 1/60th or higher for flash sync speed. The 3100Z at wide angle in Auto mode will set the shutter speed to 1/30th even when the flash is on and 1/90th at telephoto. Also I notice 2 things when comparing my 3100Z to my Epson 850Z. The shutter release on the 3100Z presses harder thus causing my wrist to want to straighten as the muscles connected to my index finger tighten. This causes the camera to rotate clockwise slightly. Also the shutter release on the 850Z is raised up higher than the 3100Z which means the index finger doesn't need to be bent as much to press it. Less of a bend means less muscle tension in the wrist. This all gets worse with action shots, like candid photos of people, since the tendency to "jerk" the trigger instead of "squeezing" it to catch just the right shot will make it harder to avoid the slight rotation of the camera. Along with trying a higher shutter speed I would also suggest practicing with the optical viewfinder. Your wrist will be in the straight position and you will notice moving the camera during the shot much more. If you use the LCD viewfinder it is easy to treat a digital camera like a video camera. Since we are used to seeing things move on a TV screen you are less likely to realize you are not holding the camera steady. I noticed I was doing this after a few months of using my Epson 750Z. I used the optical viewfinder for awhile to break myself of the habit. The last thing I can think of is I always try to press the shutter release halfway down, wait till it is done focussing, then press the shutter release all the way down to take the shot. When I don't want to wait that long and press the shutter release all the way down right away I tend to get more blurry shots. I am not sure if this is because I have "jerked" the trigger so the camera can't focus while it is being moved or it is motion blur and not a focus issue or if the camera fires even if it hasn't found a good focus when it hasn't been given a chance to pre-focus.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Manual Shutter Moves
That is exactly what happens if you turn off the LCD. It goes into AUTO EXPOSURE. The same thing happens if you are in SHUTTER PRIORITY MODE. APERTURE PRIORITY MODE keeps your setting when going to just the viewfinder. I guess they did this because there is no way to change your settings with the screen off. It would be nice be able to keep those settings for situations where the light is not going to change and you want to save the battery. On the other hand, in manual mode I like the confirmation screen to be sure that the light didn't change.
3100Z Focus Problems
re you sure the out of focus condition is due to the actually focus or do to motion blur? I think the 3100Z in auto and flash on will set the shutter speed fairly low like 1/30th of a second for wide angle and 1/90th for full telephoto. This may not be fast enough to avoid motion blur. I would suggest using manual mode and shutter priority and set the shutter speed to 1/100th of a second. This won't effect the flash output but will reduce the amount of ambient light being captured which could cause long range shots to become darker in the distance. Name of the game, don't be afraid to take it off auto mode and experiment with manual setting.
External Flash
The aperature error is due to the fact that the lens in not a constant aperature design. The settings on the LCD are assuming you are at full wide angle setting. As this lens moves towards telephoto, the aperature changes about 2/3 of an f-stop due to the mechanical movement of the lens elements. So a manual setting of f4.0 at full telephoto will be more llike f5.0 in reality. It is too bad Epson could not make the mechanical aperature adjust to compensate, but every nice feature costs something. I have not had any issue with the shutter speed changing. One guess is that the camera has shutter speed/aperature combinations that it can't achieve due to mechanical limitations, so it chooses the available combination. Another is that it wasn't in manual mode, but rather aperature priority mode and the final adjustments changed the speed.
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Epson PhotoPC 3100Z Digital Camera Logo
49 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
