Question about iLO MP3 Player
My name is Joe Ritchie, i have a GXMP-556 which is not working at the moment. I tried switching on the GXMP-556 but it goes to loading and gets hang. I have tried resetting the device the button provide behind the device but still no use. Could you please help on this as it is a gift that i got from my father and he is no more.
2 Suggested Answers
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: Help me please.......
blu - If you have a manual, find the reset method, use it, and post it here for everyone's benefit - there is no webpage or support for this product from the manufacturer
chg - there is no way to acquire it online, sorry; just so you know, this is the worst Mp3 player ever invented
Posted on May 30, 2008
I have a T104R timer and not sure how to wire it. I have 240v supply from breaker box, 2 black wires and both hot. Does it matter which wire goes to the#1 terminal and which one goes to #3 terminal....
Two hot wires from the panel go to "line" and two wires from motor go to "load". See the diagram on the inside of the door. You should consider running the "load" to a 220 wall switch and then to the motor so you can turn it off quickly if necessary without fooling with the timer.
May 30, 2011 | Intermatic T104R 208-277Volt 40-amp Timer...
What style of sunglasses are in at the moment in Hollywood? Just wanting to know from those who follow the trends, what style of sunglasses are popular at the moment for women? Are the large 'nicole...
Aviators are back at the moment -
http://img2.timeinc.net/people/i/2006/gallery/whatshotnow/060703/jennifer_aniston.jpg
...which means you are probably too late because something new will be here any moment.
Marchon seems to be the new big name:
http://www.framesdirectblog.com/celebrity-eyewear-sightings-for-january-2010/
Nov 07, 2010 | Clothing Accessories
Curcuit breaker goes off at reset
Have you switched off all switches at the pool filter or anywhere else that breaker supplies downstream? That needs to be done before you reset the breaker... Then you turn on each appliance (if more than one) in order and check which is tripping the breaker... That appliance is faulty and needs to be fixed... If everything is off downstream of the breaker and it keeps tripping itself, I would get an electrician to look at it as it could be very dangerous to investigate further yourself. You could try another breaker switch, but be sure that the mains power to your premises is switched off to isolate the breaker box before you remove any breakers.
Jun 15, 2009 | Electric Circuit Breaker Panel Box For ...
Getting stuck on the initial, splash, load up screen
have u charged the batteries fully and try, evenif the problem persists go for a battery replacement.
Jun 03, 2009 | Sony Network Walkman NW-A3000 MP3 Player
What kind of oil goes in the crank case of an 82 125 tri moto? 5-30... 30....?
10w40 Any major brand i.e. Shell, Mobil, Pennzoil, Quaker State.
Pleas take a moment to rate this answer. Thanks Joe!
Apr 11, 2009 | 1982 Yamaha XJ 650
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Lose connection after reboot and...
Hi Ritchie
Have you tried installing firmware for router again? Could be a glitch in the firmware.
Give your network card a Static IP address, gateway and set dns to router's IP? Found that some times this happens on auto asign.
If tried all above take in to repair centre phisical hardware problem or replace it.
Feel free to Search the Repair Service Directory on this site for a centre near you.
Regards
Go-Tech
Dec 16, 2008 | Belkin (F5D5231-4) Router
Indicator switch not working properly
When I use the indicators the left is working fine, but whn I go to use the right hand indicator it only works intermittently and I have to fiddle with the indicator switch stalk to get it to work. It may only be that there is dirt after getting in somewhere but I have no idea.
Aug 06, 2008 | Mazda 323 Cars & Trucks
144 people viewed this question
Top iLO Audio Players & Recorders Experts
Siul Oyaratgam
Rick
Rick
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
