Question about Philips ToUcam Fun II Webcam
Computer shutting down(logging off)
Whenever I plug in my webcam to my USB port, my computer shuts down automatically.
  • romantic16th Nov 30, 2008
    The computer shut down when I turn on my webcam.
  • loula_bunny2 Dec 18, 2008
    the screen goes off but the computer is still working whenever i connect any device to the usb (camer,a flash memory...etc)
    President:
  • 8,637 Answers
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Feb 02, 2009
Laptop restarts after shutdown
This sounds like the On/Off program in the "Programs and Features" section of the computer. On newer computers, there is a feature called "On/Off", and what this does is it keeps power going to the USB ports on the computer so you can charge things and keep things plugged in. Sometimes, if you have certain things plugged into a USB port, and you shut down your computer, the USB ports will "wake" your computer up and turn it back on. Simple things like a wireless mouse will cause this, I know because I use a Logitech Trackball mouse and it's wireless. I had the same issue, and found out that simply flipping the switch on the mouse itself(turning it off), solved my problem. I would recommend either shutting the external devices off when you shut down, or just completely unplug everything from the USB ports(minus the keyboard).
Aug 26, 2016 | Dell Inspiron N7110 I17r-6434dbk...
Logitech QuickCam Deluxe for Notebooks webcam immediatelly shuts down my Compaq laptop as soon as it's plugged into the USB port.
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 26, 2013 | Logitech QuickCam Deluxe for Notebooks
My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
Jun 23, 2012 | Dell Latitude D410 Notebook
I have a Creative Live ! Optia AF Webcam. If i put the USB of the Webcam in the USB-Slot (1 of 4 USB-Slots and all tested), i get a Bluescreen Error and my Computer shuts down. Is my Webcam destroyed? The...
A bluescreen error is rarely a good sign, but sometimes it's fixable. Have you tried plugging the webcam into a different USB port? Also have you tried unplugging some unnecessary USB devices and then using the webcam? You may be draining too much power from the PSU with USB devices and the PC shuts down to prevent damage. Have you been able to test on a different computer to see if the problems happens there as well?
Mar 24, 2011 | Creative Labs WebCam Live!
I open my webcam it,s start normal after i chat get dark , hence i shut down it, work again after 20 minits or 30 mnints dark again , so please what can i do
If you are working on a laptop - check the power setting in the control panel. It may be shutting down peripherals such as USB ports when it thinks you have not been there for a while.
Change the power settings to not shut anything down when you are plugged in.
Dec 06, 2010 | Computers & Internet
Pc shuts down after I turn on cam and I don't know why. how can I fix it?
Check the Event Viewer if there is any Error Log related with this problem. Check the USB port and also you probably might need to re-install the Webcam again.
May 04, 2010 | Intel Easy PC Camera Webcam
Seagate 1.5 TB Free Agent will not turn off
Definitely, You must turn off the External Hard drive when it is not in use, because as it is external and it comes with an external power supply,the power supply will not cut-off automatically when the computer is turned off.This is not the case for Internal hard drives that are built-in in the computers, their power supply will cut off automatically when the computer is shut down. You can turn ON the external HDD when ever you need, that is even when u are working with the computer and if you doesnt need the hard drive then you can left it OFF....When ever you need the hard drive, you can just turn ON...and dont unplug and plug the USB wire frequently, let it be plugged in the computer. Whenever there is a need unplug and take it away. Because if you unplug and plug it back many times, then the usb port may become wide, which results in frequent disconnection of the device that is connected to that particular usb port...
Guess it is useful....
Apr 05, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
My girlfriend got a dell inspirion mini 10 for christmas and we've been using it's webcam and if she doesn't have the power cable in the computer it runs fine, but when she plugs the power cable into the...
Thats just your computer ending the process of skype.
As for the pc shutting down automaticly it can be that its oveheating!!
On my Dell Inspiron 2200 I get the Blue Screen every 2 hours and I dont mind.
Might be bad memory
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
VX-1000 problems
Start- right click my computer - properties - hardware - device manager. Click on the + signs to expand links, find your camera, is there any question or exclamation marks showing, is so, right click & see what it says.
If nothing shows up as wrong, un-install your cam in device manager, restart your computer,(cam unplugged) when up & running, plug your cam back in & system will see it as new device & install it.
Hope this helps your issue.
Have a nice day.
Oct 01, 2009 | Microsoft LifeCam VX-1000 Webcam
Logitech Quickcam Fusion!
Instead of plugging the webcam in after the computer is running, I plugged in while it was shut down. The first time the computer booted with the webcam attached it took approximatly 2 minutes longer to boot, but every boot after has been as fast as ever. Webcam works great now!
Feb 19, 2008 | Logitech QuickCam Fusion Webcam
Philips ToUcam Fun II Webcam Logo
83 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
