Question about Konica Minolta DiALTA Di200 Copier
Co500 Di3510 is the model of our copier and I don't know how to fix it. It shows random numbers... and the Co500 whatever... don't know what to do.. Help...
  • pty_online Sep 02, 2008
    My copier, Di3510, shows random number.
    The problem maybe is the "Co500"....?
    help...
  • 145 Answers
Locate a pin hole on the right side of the disply panel,and use a paper clip,be very gental and depress it and wait for a samll dot on the left side of the disply panel,as soon as you see it press #3 and than a menue well pop up look for trouble reset botton and turn machine off from the main switch and back on
good luck
Posted on Sep 29, 2008
How to add konica minolta bizhub Di3510 on windows xp
Down load the driver from konicaminolta or use the disk with the copier.
Jan 22, 2014 | Minolta Di3510 All-In-One Laser Printer
How do i turn off dhcp & set a static ip on a di3510?
Your turn off DHPC at the DHPC server, if you wish to set a manual IP at the Copier, log in as administrator, and set up the for static IP vise DHCP
Jan 17, 2014 | Konica Minolta Di3510 AllInOne Laser...
Minolta Di3510 cannot make copies error code Co500
mam/sir,
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jul 30, 2012 | Minolta Di3510f Bizhub Copier
Malfunction detected, code CO500 on our printer, model Di251.
my di2010 has a co500 code on it after someone tried to run a transparency thru it.
Jun 25, 2009 | Minolta Di251 All-In-One Printer
Error CO500
This error code indicates low temperature at warmup.Can somestime be reset IF you can find the reset switch.On earlier models it was behind a small panel on the innards of the machine after you open the front door.Good Luck!
Mar 30, 2009 | Minolta Di3010 Copier
Konica minolta Di3510 Tech Password
if three times you tried with wrong password at saem time you have to change ram
Oct 02, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta Di351 Dialta
Try shutting the copier down and then unplugging it from the wall for 15 minutes.
If this does not reset the device, a technician is required.
Jun 10, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
235 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
