Question about Garmin GPS
I have Garmin mobile Pc On my tablet pc!When I try to calculate a route from my home Address(Middlesbrough)to Ijmuiden(Holland) I get a warning message that there is not enough memory,when I know that is plenty of spare memory on the pc
hydetech
  • 113 Answers
SOURCE: garmin nuvi 200 route calculation problem
Sounds like a major software failure. . .
Hold a finger on the upper right corner of the screen while powering up the unit. This should do a master reset.
The go here to download an update.
Posted on Oct 26, 2007
  • 504 Answers
SOURCE: garmin 660
Have you updated the software since you purchased the unit? If not, go to Garmin's site, download WebUpdater and check to see if there is an update to the unit's software. If so, download this and see if it helps. If not, try downloading the same version of the software again. This might help also.
Posted on Jan 28, 2008
  • 4 Answers
SOURCE: Route calculation Error on Garmin GPSmap 60CSx
Try re-setting your gps by simultaneously pressing the Enter and Page buttons while turning it on if that doesn't work check your firmware i found the latest one v 3.90 would shut off my gps when recalculating v 3.70 is stable Garmin know that the new firmware can cause problems
Posted on Jul 04, 2009
  • 67 Answers
SOURCE: no data available and no maps downloaded
it may just be that the maps are deselected. to correct this go into the tools/settings/map and then at the bottom of the screen in the middle you will see map info tap that and then at the next screen it will show you the maps which are installed if there are any without ticks just tap the box. tap ok and try again if. if there are no map choices then you will need to reinstall the maps on your unit
Posted on Apr 28, 2010
SOURCE: Garmin Nuvi 760 gps Unable to calculate route No roads
I have same issue Garmin Nuvi 760 gps Unable to calculate route No roads near starting point started this morning. Has worked fine for 2 years till today. David W
Posted on Aug 30, 2010
I have lost all my maps on my garmin nuvi 255W-
Do a hard reset on your GPS. Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to download new maps to it.
Mar 19, 2017 | Garmin Nuvi 200 205 250 255 260 W
We have a new Garmin Nuvi 55 LM and it keeps showing that we are in Chicago when we are in eastern Kentucky.
It appears you haven't entered your home address in set up, it it is confused to where you live . follow the user manual and set this up and it should be ok.
Jan 05, 2016 | Garmin GPS
Cannot Calculate the route - Garmin Nuvi 3760
My probleme:
When you want to select (established) a route (Finding Location or Planing a Trip) the device machine can not calculate route and displays the following message: "Route waypoint memory is full". The device is Garmin 3760T.
I found the solution:
1. Start the device.
2. Touch "Wiew Map or Map"
3. Touch on bottom right of screen (Speed)
4. Hold your finger on top center of screen for 5-10 seconds (the speed semicircle between Trip A and Trip B). The unit would go into "Diagnostic Page".
5. Select "Clear all user data" and confirm.
Warning: will erase all user-selected data (Home, Recently Found, Favorites, Trip Planner, ....).
Mar 04, 2014 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
My Gamin Nuvi can't unlock maps
Use a Garmin 1450
The Garmin Nuvi 1450 can be used while driving or walking.
While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets.
As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area.
Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass.
Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections.
Input the name of the state or county, if it is out of town.
Then tap "Spell city." Spell out the name of the city using the pop up keyboard.
Press "Done."
Enter the address number and press "Done."
Then enter the street name and press "Done."
The "Go" screen opens automatically.
Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address.
Follow the voice prompts and map highlight to your destination.
Navigate Using Coordinates
Tap "Where to?" and then tap "Coordinates."
Tap the coordinate you want to adjust/input a new coordinate.
Tap "Format" to choose the right coordinate format for the map you are using.
Enter the coordinates. Tap "Next."
Tap the green "Go" button to calculate a route.
Use the Map Page
Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn. Tap the bar across the top with the next direction listed on it to see a list of all directions.
Tap the plus or minus signs on the right side of the screen to zoom in or out.
Press the spinning arrow in the lower left corner of the screen to return to the main menu.
Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Hope this helps
Oct 29, 2012 | Garmin Nuvi 1450 GPS Standard Red LED Wall...
Wont calculat route
sat nav needs a valid gps signal to start calculating route, even if it found entered address. Address is searched on built-in map, not live gps position. That means, sat nav may have problem with gps signal. Try to reset device to its factory settings first. hope this helps
Nov 01, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi Unable to calculate route No roads near starting poin
Its a problem you need to address with Garmin on this model before warranty runs out
Please rate our help to keep the FREE service onlinew++++Thank you for using FIXYA
Sep 11, 2009 | Garmin nuvi 350 GPS Receiver
My garmin
it may be trying to get you back on track or if when turning it on it trys to take you a previously sort location you may have set this as your home. make sure your actual home address is stored as your home address on the gps unit.
Jan 10, 2008 | Tomtom GO 910 GPS Receiver
GPS Logo
185 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
