Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint Dishwasher BF1620 Fault codes
The first and second green lights flash together and nothing works. There is also some water left in the bottom. What does this fault mean please?
  • harpo55 Sep 07, 2008
    I have same problem. In my case I took washer out, turned on side to access bottom sump and resurected and it started to go. Double flashing lights soon return tho.
    Harpo
2 Suggested Answers
SOURCE: hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Posted on Sep 20, 2008
Dishwasher Hotpoint bf1620
That is not a valid model number
Aug 08, 2014 | Hotpoint Dishwashers
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf1620 dishwasher flashing light fault
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
Hotpoint dishwasher bf1620 - 1st light indicator (heavy soil)flashing. information from hotpoint and manual useless
Hello!
I found out from hotpoint that the first flashing indicator means that the 'float switch' has been activated meaning that the base tray 'may' be leaking. I don't know whether this is a tactic to get their repair man out to fix it.
I was wondering whether there is a way to reset the switch and try re-running a programme as my base tray doesn't seem to be leaking.
I hope this helps a bit
May 02, 2008 | Dishwashers
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
Flashing green light
Hi there. It looks like water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Mar 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
372 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
