Question about Kyocera FS-3900DN Laser Printer
Call service 6000:0098269
Our printer just stop and appear this code call service 6000:0098269, is anyone there can translate it? Thank you, edgar_velasco@yahoo.com
  • Anonymous Oct 15, 2008
    i have an Kyocera FS 2000D which displays error 6000 i checked the thermal cutout and it was open i shorted it with a piece of wire to see whether it will operate but i am getting the same error.Is there a procedure where the error can be reset from the service mode?
  • ppoudevigne Feb 20, 2009
    After a paper jam the printer put this message 'call service 6000:0161378'
    Problem Solver:
  • 14 Answers
6000 Broken fuser heater lamp wire
The temperature does not reach 100°C/
212°F after the fuser heater lamp has
been turned on continuously for 30 s.
30/31 ppm printer (EUR/USA model):
The temperature does not rise by 1°C/
1.8°F after the fuser heater lamp has
been turned on continuously for 5 s during
printing.
35/37 and 45/47 ppm printers (EUR/USA
model):
Fuser thermistor M detection
temperature does not rise by 1°C/1.8°F
after the fuser heater lamp has been
turned on continuously for 10 s during
warm-up or at standby.
Fuser thermistor S detection
printing.
Poor contact in the
fuser thermistor M
connector terminals.
Reinsert the connector (See page P.1-5-19).
Fuser thermistor M
installed incorrectly.
Check and reinstall if necessary (See page
P.1-5-19).
Thermal cutout
triggered.
Check for continuity. If none, replace the
thermal cutout (See page P.1-5-19).
Fuser heater lamp
P.1-5-19).
Broken fuser
heater lamp wire.
fuser heater lamp (See page P.1-5-15).
Posted on Sep 16, 2008
  • 300 Answers
You need to replace the fuser. 6000 means fuser error 0098269 is your page count
Posted on Sep 02, 2008
How can I apply for Edgars account on line?
Hello, call edgars cust service and apply there.
May 07, 2015 | Computers & Internet
Thank would guide me about this problem: my freezer frigidaire ffu17f5hwd tells me E8, referred this error
Good Afternoon edgar corro, thanks for your post!
Based off the information you have provided your Frigidaire freezer is displaying an error code "E8". An "E8" error code typically stands for a shorted thermistor this could be a possible miscommunication with the wiring harness, control board, or thermistor. Since it could be anyone of these underlying issues I would suggest contacting a professional technician since they have the appropriate tools to pinpoint the parts needed for repair. Best of luck! -Matt
Feb 05, 2015 | Frigidaire Freezers
Epson stylus 1410 both red light blinking
Thank you very much Edgar, you saved my day!
definitely voted for! big thumb up!
Jul 22, 2012 | Epson Stylus Photo 1410 Printer
I have a printer samsung scx-4200. when i click start button in order to make a copy it remains unchanged no voice at all and no errors as well, when i connect to the PC it is being detected by PC but the...
Appears to be a driver problem. Toward the end of the page of this supplied link are purportedly a couple of solutions. They may require translations. Either Google translate or Q Translate freeware may assist.
Updating to Mavericks Samsung Scx 4200 can no longer print and scan
Dec 09, 2017 | Samsung SCX 4200 All-In-One Laser Printer
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Aug 23, 2009 | Kyocera Mita Office Equipment & Supplies
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
Aug 03, 2009 | Ricoh Aficio AP410N Laser Printer
Printer says out of ink, won't print
Greetings,
Try this In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
This isn't set level but it disable ink check. The LED warning still blink but no error code appear anymore.
Regards,
TechSup1
Apr 30, 2009 | HP Deskjet 5940 Photo InkJet Printer
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
Kyocera FS-3900DN Laser Printer Logo
4,008 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
