Question about HP LaserJet 2420dn Printer
Defective -printer HP Laserjet 2420
Hi, I have a problem with my printer HP Laserjet 2420, Its fuser Assembly is defective. Now, I would like to inquire how much is the cost of the repair.
    Genius:
  • 1,689 Answers
The only people who can give you accurate information is an authorised HP service rep. Call HP suppor to find out. Normaly HP does not support self service. If it is an internal part that is not considered a user changeable part, HP will ask you to bring the printer to their authorized service rep.
From experience, I have seen the fuser go defective on a laser priinter. In some models, the fuser is user changeable, and on others it is not.
Sometimes when the fuser is blown, there are other problems along with it. You may find that it is more feasible to change the printer for a new one, especialy if it is out of warranty. You can invest a fair amount of money and then have a failure shortly after because of its age.
If your printer is more than 5 years old, it may not be supported by any of the newer operating systems coming out. You will have to consider that in the near future you may run in to this type of problem.
Jerry G.
Posted on Sep 02, 2008
    Genius:
  • 2,120 Answers
$220.00, not including labor.
How much voltage it takes a fuser to heat
120 volts AC in the US. Wattage is between 700- 1200.
Apr 01, 2014 | HP LaserJet 2420 Printer
I have an HP laserjet 2420 which has suddenly started making an alarming cracking noise when printing. I have checked the papertrays and nothing seems to be amiss. Any ideas?
> Are you observed this noise while printer initializing?(after switch on the printer)>Remove back cover, check the fuser assm screws, tighten or slacked?>If found any slacked, replace little lengthy screws then existing screws, ensure that don't try to do fully tighten the screws.>Put more pressure to tighten the left down fuser screw.>Replace 20t fuser driving gear.
Dec 13, 2011 | HP LaserJet 2420 Printer
Hp 2420 leaves vertical line across the page. we changed the fuser 7 months ago
It sounds like you may need to change it again. These printers use a Teflon coated heat roller in the fuser. If you print envelopes that will scar the heat rolller, this can also happen if there is a piece of paper jammed in the fuser assembly and it scraped the fuser roller. Open the back of the printer and look at the roller in the fuser. I would bet that you see the roller is damaged. Here is a link to a post about the Laserjet 2100 printer with the same issue. It has pictures of the roller and what to look for, the fuser is different but the principle is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 20, 2011 | HP LaserJet 2420dn Printer
Our HP Laserjet 2420 printer is printing with black lines, can you help, we have cleaned the head
First try to change the cartrigde with a new one,if the problem persist in the main part you have a problem with the fuser (you need to replace the fixing film).Fixing film is an inside track fuser, fuser can change separately or altogether.
http://www.precisionroller.com/img/J3388.jpg this is the fixing film.First try to change the cartridge!!!
If i have been useful please give me a vote :).Thanks
Apr 06, 2011 | HP LaserJet 2420 Printer
I have hp laserjer 2420 printer, it is not performing printing and display error "50.4 fuser error " what i shall do now ?
The message says that your printer has a bad fuser.
It is going to have to be replaced.
The part number if you are in the states is RM1-1491-000CN
Feb 02, 2011 | HP LaserJet 2420 Printer
My hp 2420 pcl 5e STOP PRINTING SUDDENLY. & showing me (FUSER ERROR) TELL ME WHAT CAN I DO TO SOLVE THIS PROBLEM I TURN IT OFF AND BACK ON 3 TIMES BUT PROBLEM IS STILL THE SAME.
Hi
Problem either fuser faulty or dc controller card faulty first check for faulty fuser & after then dc controller fuse of fuser.
Thanks
Sep 25, 2010 | HP LaserJet 2420 Printer
WE HAVE A PAPER JAM ON THE BACK FUSER OF HP LASERJET 2420. A PIECE OF PAPER IS COMPLETELY WRAPPED AROUND IT.
You can attempt to remove the fuser from the machine to have better access to the paper inside. It is very easy to damage the fuser roller and film when removing a piece of paper wrapped around inside.
We recommend calling for service, but worst case is you try yourself and can't get the paper out then you would just order a new fuser.
We can get you the fuser. Just call 262-993-1551. We offer free shipping.
Sep 02, 2010 | HP LaserJet 2420 Printer
HP Laserjet 2420 is printing a vertical black streak along left side of page.
This is either a defect in the cartridge. Or a defect i the fusing unit. Try a different cartridge to see if it goes away. Most all print quality issues on HP's are from the cartridge. If the cartridge does not fix the problem then the fuser film is goin bad. You can replace the fusing unit or find a local guy that can do just the film. Much cheaper. If the line down the side kind of "rubs" off like the toner is loose on the page then it is definately the film.
Jan 06, 2010 | HP LaserJet 2420 Printer
My hp 2420 is printing a black line-form
Lines are usually caused by the toner cartridge or the fuser. In order to determine the cause you can replace the toner and see if the lines go away. If not then it is in the fuser assembly and you would need to replace the fuser.
Nov 02, 2009 | HP LaserJet 2420 Printer
Install fuser
please reference the service manual from page 89 shows how to remove and reinstall the fuser unit, download from:
http://www.google.ca/search?hl=zh-CN&q=HP+2420+laser+jet+service+manual&btnG=Google+%E6%90%9C%E7%B4%A2&aq=f&oq=
choose second one PDF file and download for a while. then go to page 89.
hope help you to fix it , and please take a rating let me know how much helped you thanks!
May 16, 2009 | HP LaserJet 2420 Printer
HP LaserJet 2420dn Printer Logo
87 people viewed this question
Ben Johnson
