You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
you can get your IMEI number by typing *#06# on your phone.. the 15 digits number that you find is your IMEI number
1. Press ( # ) on your phone 2. To get ( p ) press ( * ) 3 times within 1sec 3. To get ( w ) press ( * ) 4 times within 1sec 4. To get ( + ) press ( * ) 2 times within1sec 5. Enter the 15 digit code 6. To get ( + ) press ( * ) 2 times within 1sec 7. Enter code number 8. Press ( # ) on your phone
Now your phone is unlocked!
If your phone isn?t unlocked after code 1 or code 7 then you have either entered the wrong IMEI or Network. Sometimes there could also be a problem with newer software versions.
Hai, You can visit the site mobileunlocker.In that site contains the unlocking instructions and unlock code for the nokia 6300.its contains the unlocking instructions for all mobiles.
i have nokia nokia 6300 vietnam need the unlock code phone restricted
1.phone model : nokia 6300 , (type ; RM-217)
2.imei # 354189029721746
3.the network where you pjone is locked to : vietnam
Handset Unlock - Instructions
Please find below the instructions to unlock your handset.
Handset Unlock Procedure for IMEI:
353508029865248
Your unlock code is:
426850229882845
Manufacturer/Model:
Nokia_6300
Nokia 6300 PHONE UNLOCK PROCEDURE PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY
UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only
using SIM cards from Vodafone Australia. In
case of difficulties, please refer to the FAQ listed below 1.Take note of the unlocking code shown above 2.Insert a Non-Vodafone Australia working
SIM card. 3.Ensure the phone is charged and then switch the phone
on. 4.Optional
Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below) 5.The phone will then display a message. The most common
is “Phone
Restricted”. Select
“undo” by pressing the middle
soft-key button. (Different message? See FAQ below) 6.Carefully read step 6 before
attempting to enter the unlock code. This step has the potential to PERMANENTLY
BLOCK YOUR PHONE!
Enter into the phone #pw+ followed
by the 15-digit unlocking code then +1#
(Unlocking code is shown above). Do not
enter the15-digit IMEI number by
mistake
To enter +
press the * (star) key two times
To enter p
press the * (star) key three times
To enter w
press the * (star) key four times
For Example: If your 15-digit unlocking code is 123456789012345, enter the following in
sequence: #pw+12456789012345+1#
(When entering the unlocking sequence it
disappears? See the FAQ below) 7.Then press “OK” 8.The handset will display “Phone
restriction off”
unlocked after successful entry of the unlocking code. This will be confirmed if
you can make and receive calls with the Non-Vodafone Australia
SIM card. (You will need reception and phone
credit with the different network provider)
Before trying the master code switch off your mobile for 15 - 20 minutes and after starting it again use my master code given below to unlock your moible.. If your IMEI no is correct than : Just use this no to unlock your mobile :6350266760 This will definitely break your mobile security code ...........enjoy ------------------------------------------- Please let me know your feed-back.
