Question about Hoover Vacuums
Lost the lid to a commercial carpet cleaner
Can you please find me a replacement lid to a Hoover Commercial Carpet Master C3842, Serial No. 010010. the lid is missing from the dirty water tank where the hoses fit into.
Ive been on to Hoover and they tell me that the above model became obsolute on 13th August - consequently all trace of this appliance has been wiped off the face of GB. This cant be true can it ? am I seriously unable to buy a lid for my cleaner because of this?
A second hand one would be absolutely fine
Many thanks
Wendy
carolynwendylane@yahoo.co.uk or 01253 316534
SOURCE: Hoover SpinScrub Carpet Cleaner
I was having the same problem, the black seal under the tank that captures the water was broken, and it wasn't getting any suction.
Posted on Feb 06, 2008
  • 384 Answers
SOURCE: carpet cleaner pick up water
water outlet are pluged soap residue seal broken or miss alined
Posted on Apr 05, 2009
SOURCE: Not Sucking the dirty water
There is a panel on the front of the waste tank. Be sure that this panel is secure.
You will know that this is the problem because no matter how many times
you replace the waste tank, it still won't **** up the dirty water. You sure
wonder if Hoover ever tested this model. I would never purchase one again.
Posted on Jul 16, 2009
  • 97 Answers
SOURCE: Hoover Steam Cleaner - dirty water is not coming up in the tank!
recovery tank (dirty water tank) not on correctly
Posted on Jul 20, 2009
SOURCE: Hoover Agility Steam Vac has no suction for the dirty water
Broken suction hose.
Posted on Dec 05, 2009
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
How can you clean spots off carpet
Office pros cleaning service is expert in carpet cleaning.They categorize our cleaning program depending upon carpet condition. Offer three types of carpet cleaning programs.
Steam clean/ Hot water extraction
Bonnet clean
Very low moisture encapsulation clean.
Office pros cleaning staff expert in spot and stain remove from carpets,use the green certified product for cleaning.So finnally I suggest for Office pros cleaning for remove the spot and stain from carpet.
Commercial Office Carpet Cleaning
Dec 30, 2013 | Vacuums
What is the best way to clean a carpet?
Vacuum the carpet. Dampen a cloth with the cleaner or stain remover you want to use. Lay the cloth on the carpet for an hour, and then blot the damp area with a dry white cloth. If the cloth is stained with carpet dyes, test another cleaning product until you find one that does not make the carpet sample bleed.
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Jun 11, 2012 | Vacuums
Hoover carpet cleaner not picking up water
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
In addition, make sure the recovery tank lid is properly aligned to the tank to seal.
Lastly, make sure the square duct is latched in place in front of the recovery tank, that links the nozzle plate to the tank lid.
Feb 14, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I need to know how to use the carpet cleaner i have got lost the instrutions
Please look at the data label, and let me know the model number. it should be something along the lines of F51XX-XXX
Sep 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Carpet Magic Steam Machine Hr 3-2 Leaks
carpet magic steam cleaner pump problems.
Apr 24, 2009 | Vacuums
Hoover Steamvac Ultra
make sure all parts are snapped in again i did the same thing.......
Mar 17, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac F5892-900 leaving lines on carpet, does not seem to spray
Is the cleaner sucking up the water like it should? If not , check that the filter on the inside of the lid has a 1/4 in. gap between the filter and the top of the lid. Either that or the water isn't completely being shut off when you release the trigger, in whcih case you would probably have to take it in for service.
Jan 31, 2008 | Hoover F5892-900 SteamVac Upright Vacuum
Vacuums Logo
47 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
