Question about Palm Treo 650 Handheld
Alalrm where is the alarm
  • 3 Answers
Or go to the 'World Clock" and at the top somewhere there should be a small bell. click on that and it should go to an alarm setting!
Posted on Oct 29, 2008
You have to add an event into the memo book. After you add the event, go to details and then check the box for alarm.
Posted on Sep 03, 2008
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
My 2007 Saab 9-3 is giving a signal that the trunk lid is open. we have closed it several times but it is still saying its open. Any help? cant figure out why this isnt going away
Why would it go away
You obviously have to check out the trunk switch
& resolve the issue with it
I would guess you can't use the security system either
until you fix the trunk sw
Feb 17, 2013 | 2007 Saab 9-3 2.0T
X type car alarm goes off for no reason
Usually these are caused by a sensor issue or the alarm module problems.
The sensors can be the tilt-tow sensor or say glass breal sensor as examples. When these go out they keep feeding in a alarm. Unless you car was in a accident in its past most of the sensors never act up. The wiring can or the connections will. These can be expensive to track down for labor cost. The other end is going to be either something called an alalrm module or all activity module aam. This is usually fixed by replacing and is not cheap ( or even close to cheap).
Jun 04, 2012 | 2002 Jaguar X-Type
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
Lost keys and keyless remote
you must go to dealer and have akey made because the one you lost probably has a theft deterant by pass built into key thats why it wont start you have a computer chip in your original key that by passed alalrm and it would start ur car they will need ur vin number
Feb 02, 2010 | 1998 Ford Windstar
I cant get my second alarm to be set on the alarm sound how do i get my second alarm off of radio of cd mode
products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
copy and paste the above link in your internet address bar under a new tab. It is your entire manual.
Hold down ALARM SET and press ALARM MODE. The Alarm 2 indicator flashes. You now have 10 seconds to begin setting Alarm 2. Note: The Alarm 2 indicator must be flashing while setting Alarm 2 wake up time or sound. To set Alarm 2 wake up time, hold down ALARM SET and press either TUNING button
For manual copy and paste this link in your internet address bar under a new tab:
Oct 14, 2009 | Bose Wave Radio
I have 99 passat, would not start, the lights are on, the battery is ok, the mechanic can not find problem, what is wrong?
hello i am an auto-electrician and they have problems with joints braking under the passenger side front floor carpet.What happens is the jionts where wires are connected brake which will give you loads of problems including electric window central locking no start alalrm not working the list goes on give me a ring if you are unshore on 07776068845 hope this will help re join and you must solder or it will happen again.
Feb 23, 2009 | 1999 Volkswagen Passat
Setting the time
Just figured it out. Thanks, anyway.
Dec 05, 2008 | GE Audio Players & Recorders
Palm Treo 650 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
