Question about HP ScanJet 3970 Flatbed Scanner
Tma problem my scanjet 3970 diplays that it has a problem with tma,
  • jose_melende Sep 27, 2008
    perdi los driver de mi scanjet hp 3970 necesito urgentemente los controladores, muchas gracias
Light in cover had failed,fitting a new cover solved problem.
Posted on Oct 23, 2008
Hp scanjet 4670´s tma does
I'm afraid there are no drivers running under Windows Vista for this unit.
If you have the W XP install disc , you could install a virtual version of W XP on your HDD (
http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 )
You could also partition your HDD (
http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one .
Dec 31, 2010 | HP ScanJet 4670 Flatbed Scanner
My hp sacanjet 3970 doesn't work
Most likely cause of the "Scanner could not be initialized" error on the HP Scanjet 3970 is due to using an incorrect power adapter and cord -- the only power module and cord that work for the HP Scanjet 3970 are these part numbers: 8120-6260 for the power cord and L1970-80003 for the power module / AC adapter I hope this info helps you.
May 23, 2010 | HP ScanJet 3970 Flatbed Scanner
I changed my Pc and I don t have an install cd for my hp scanjet 3970.Ca you help me?
Here you are:
http://www.driverstock.com/download-HP-3970-driver/10-7-4669/index.html
Ok be sure to select the coresponding windows and type the security code accordingly.
Good luck
Uttam
Jan 26, 2010 | HP ScanJet 3970 Flatbed Scanner
Hp scanjet 3970 will not scan slides with Vista
HP only have a basic vista driver for this scanner which won't give full functionality.
Sep 19, 2009 | HP ScanJet 3970 Flatbed Scanner
I WANT TO KNOW THE MEAN OF ''ERROR 06'' IN HP SCANJET 8270 AND THE POSIBLE SOLUTIONS... THANKS
If LCD displays Error 06 or Error 09 , the TMA might require service
Press SCAN PICTUREc00068011.jpg button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected). NOTE: The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
Jul 02, 2009 | Office Equipment & Supplies
Fuse for hp 3970
After you have UnScrewed and Opened Up the Scanner.
On the Circuit Board (Green Board with Electronic Components) just where you Plug in the Power Pin there is a Small Glass Tube Looking Component.
You need to replace that with a 1.2mA Fuse.
Hope this Helps
Apr 03, 2009 | HP scanjet 3970 digital flatbed scanner
HP scanjet 3970
hi frined
take ur adper & show the store he will give u same needed code of power u have to nearest electronic or electrical store there u get a power cable
thmx using fixya
Apr 06, 2008 | HP scanjet 3970 digital flatbed scanner
HP ScanJet 3970 Flatbed Scanner Logo
518 people viewed this question
Ben Johnson
