Question about Epson PhotoPC 3100Z Digital Camera
How do I calibrate my monitor? I have a new epson 3100z and a Epson photo Printer890... PIM is a joke..... I use adobe for image editing and image expert to print... My photos look great on the monitor but when I print, the dark blue comes out purple... and the skin tone looks washed out, no color
    Master:
  • 542 Answers
In order to get out to the printer what your camera captured three things must be calibrated (profiled). First of all your camera must be profiled to descibe to the other elements what is the color space., Next the monitor must be profiled, and all of the Adobe, and other free programs that tell you it can calibrate your monitor will not do the job. You have to invest in one of the packages out there that will do it ACCURATELY. Finally, and maybe most important, is that your printer must be profiled for every type of paper and resolution setting. Once you achieve this, you will get accurate prints out of your 890 (I have it also). I suggest you look up several programs which will give you more detail on the Color Profiling Issue....Try Qimage, Monaco EZColor2, and Profile Prism (New ...to create a profile for your camera).
Posted on Sep 13, 2005
    Master:
  • 542 Answers
PIM uses the exif-info in your original jpg. I'm not sure, but I think if you edit the picture this exif becomes useless (because it relates to the original), even if you save the file including the exif-info. Also, you apparently you need additional printing software to make use of PIM. This was in the news on this site sometime ago. If you search, you can find out where to download this software. If you've got photoshop, you should also have a program called adobe gamma. With this you can calibrate your monitor. You should be able to find it under start->configuration. When you have calibrated your monitor, you should of course not use the settings on your printer that push up the saturation/contrast of your images, or else you will get Disney-colors. (I made the mistake of using 'digital camera correction' on the 1270 myself). I get good results printing from photoshop, with a calibrated monitor as well as some media profiles for the paper I use (just calibrating your monitor will probably be enough to get pictures that are close to what is on the screen, I just haven't tried that yet). If you want to calibrate your monitor, there are some good tips on http://come.to/digitaldarkroom. (it's where I got what I know about this). Btw, I cant seem to reach the site right now, but it will probably be up again in a few hours.
SOURCE:
I recently purchased an Epson Photo PC 3100Z Digital Camera (used). It appears to take pictures but does not store in on the memory card. A code 181 flashes in the top display window. The memory card is...
It is probably having trouble with the capacity of the memory card. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
You don't say what type of memory card you have. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 22, 2011 | Epson PhotoPC 3100Z Digital Camera
Epson 3100Z camera
I had one of these cameras, and all I can say isd that it was a joy in every respect. Fast accurate focus, feature normally seen on much more expensive cameras, build quality etc. The 3.1mp sensor gives photo's of high quality up to A4 site. I have an a3 phto taken by mine on our lounge wall!n Value? well, I'd pay up to £80 depending on its condition. If you do decide to buy it, make sure you see a photo produced by it in your presance if possible. Good luck with it!
Jun 21, 2008 | Epson PhotoPC 3100Z Digital Camera
Calibration of monitor
Here's the tip I used years ago on CRT's suffering this same fate.
Take one of your printed photo's and hold it next to the screen (with the same photo on it running in whatever software you want to print from)
Now using the monitors controls, make the monitor look like your photo that you have printed.
Nice and dark now like the photo, good =)
Now adjust the software to what you want it to look like when printed.
Looking good so far..ok
Save those settings in the program. then re adjust the monitor back to how you want it to look normally (as it was before basically)
Not the ideal soloution, but it works and it's free.
Apr 15, 2008 | HP f1905 19" Flat Panel LCD Monitor
PIM and CD400
Try import instead of open, then click print image matching. This is how it works in PS7.
Sep 13, 2005 | Sony Mavica MVC-CD400 Digital Camera
Epson 3100Z battery life/power consumption
I have only had my 3100Z for about 3 months but I have found the battery life outstanding. I have the NI-MH batteries and haven't actually counted the number of pictures I take between chargings but it seems as if it is 200 or more. I also have many menu changes, view the photos in the camera and leave it on between shots. I also have sleep set for 30 seconds. I have actually never run the batteries down but recharged them twice in anticipation of needing plenty of power when I planned to take a lot of pictures. I'm guessing that you might have some faulty batteries.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Image quality of the 3100z's JPEG format?
I don't think you will find any major difference in quality with Epson's 3000 or 3100 compresssion compared to Canon's. I use the 3000z and shoot in low compression giving a file size about 850k - 1000k.
3100z software control
I think that to use this nice camera as a "web-cam" is really a wastage!
This fine camera should take the best photos I owned, even compared with my Canon D-SLR.
Flash for 3100Z
I use a Sunpak 433D flash with my Epson 850Z camera. Do a search for vivitar in this forum and you should get a lot of hits.
Epson 3100 life battery
I have a 3100z and you are right that alkaline batteries do not last long. The thing to do is buy a couple of sets of NiMH rechargable batteries and they last much longer. I,ve just been on holiday and had no problems at all with the batteries. (Although the camera does not give much warning when they need replacing).
Why doesn't the Image Expert software recognize the camera?
If you have a version of Image Expert from a different camera, printer, or other product, make sure you install the version of Image Expert included on your PhotoPC 3100Z Software CD-ROM and use it when you are connecting to your camera.
Sep 12, 2005 | Epson PhotoPC 3100Z Digital Camera
Epson PhotoPC 3100Z Digital Camera Logo
251 people viewed this question
Top Epson Cameras Experts
Steven Wander
Steven Wander
Terry Herrera
Harrie
Are you an Epson Camera Expert? Answer questions, earn points and help others
