Question about Seagate (ST380011A) 80 GB IDE Hard Drive
Bad sectors removal and formating Seagate 80 GB
My seagate 80 gb hard was corrupted and windows not working.I deleted all teh particions and after new particions,windows was not being installed.Soem sectors in the start are bad.How can i remove tehse bad sectors and can install the window? Saqib
  • 34 Answers
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Posted on Sep 02, 2008
My hard give bad sector st380011a seagate muhammadusamabinliaqat@gmail.com muhammadusamabinliaqat@yahoo.com
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and attempt to repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Dec 18, 2010 | Seagate (ST380011A) 80 GB IDE Hard Drive
Seagate Barracuda 7200.7 ST380011A 80 GB stop working, it would not work properly, keeps freeze up
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Nov 28, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I bought gb seagate Hard disk i am not able to formate from DM or fdisk utility, & from xp i lost 24 gb space then what can i do.
have you tried
click start run type cmd then type chkdsk/r/f which will automatically fix any corrupt files and scan for bad sectors and recover on your hard drive then defragment your hard drive
hope this helps
Sep 28, 2010 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
How can i remove bad sectors from my hard disk?????
You can not remove bad sectors from hard drives. Bad sectors are parts of the disk that become unreadable / unwriteable. Hard drives made in recent years simply stop using that part of the drive.
Apr 07, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My seagate 80 gb ide has got its MBR corrupt, help me out ihave tried almost all things, i want a direct MBR writer. please
the same problem i got few days back. but did;t find any proper sollution. The only thing u can do to format it.
Jan 06, 2010 | Seagate (ST380011A) 80 GB IDE Hard Drive
Barracuda 7200 6Y160M0 FW YAR51HW0
do a low level format with a software from hddgurudot com its free software. run it and choose this drive for low level format.it runs through windows it will make a new list of bad sectors and add it to the p list of the hard drive company settings
datarecoveryfactory
Jun 09, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Problem related Seagate Hard Disk
i also encountered that problem about using seagate. first make sure that theres no loose connection between the MotherB and HardDisk. Or maybe it has a virus or a bad sector.,Try this, if you have another hard disk, try to make the 80gb a slave drive. then format it using windows base process (Right click the drive then FORMAT). or try DEFRAGMENTATION and scandisk for that drive.
Dec 01, 2008 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
394 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
