Question about Home
Hansgrohe shower Hi, just fitted a new hansgrohe thermostat concealed shower unit to a gravity system using existing pipework thoughly flushed both hot and cold sides through the Ibox then fitted the thermostat unit but when i try to turn the the temperature to the cold it just shuts the cold water supply. So no blockage getting to the Ibox do you think the non return vale within the thermostat unit could be faulty bearing in mind this is a brand new shower unit
  • tegsbo Sep 03, 2008
    yes it is in the correct way, maybe your right its just brand new junk!!!!!
    Thanks for the reply keemo68
  • Anonymous Mar 16, 2014
    fitting instructions
    President:
  • 1,263 Answers
It's possible sometimes you can get brand new junk. one question is the thermo coupler in the right postion? i would check to make sure that it is indeed picking up the temp like it should.
Posted on Sep 03, 2008
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Shower hose keeps disconnecting from metal connector
It seems you may need a new hose. You can contact Hansgrohe Tech at 1-800-334-0455 and we can handle the replacement for you.
Apr 10, 2013 | Hansgrohe 28274000 Techniflex 80in....
No pressure in Hansgrohe shower when on hot setting
This is most likely debris in the filter screens on the thermostat cartridge or the thermostat cartridge has worn out. Cleaning the filter screens may resolve the issue. If cleaning the filter screens does not resolve you may need to purchase a new thermostat cartridge. If you need further information feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Oct 27, 2012 | Hansgrohe Shower 26101 Pharo Prestige...
How do I change a hansgrohe thermostatic shower cartridge
Different valves have different techniques for replacing thermostatic cartridges. Without knowing specific model numbers I cannot give accurate instructions for the procedure. If you need help identifying the valve feel free to contact me at Hansgrohe Technical. 1-800-334-0455. press 2 for tech and ask for David Scarborough. I'd be happy to help.
Aug 30, 2012 | Hansgrohe Home
Hansgrohe shower thermostat: water is getting only Lukewarm. Hot water ok in sink and throughout rest of house.
The first thing to try is cleaning the filter screens on the thermostatic cartridge. Hansgrohe thermostat valves have filter screens to protect the element from debris or water deposits. If they begin to get clogged the valve will have a hard time regulating temperature.
Jul 28, 2012 | Home
How to un-fit Hansgrohe Chroma 3-ways handshower?
Hansgrohe hand showers have filtration sometimes on the inlet side of the hand shower. You must unscrew the smooth conical nut from the handshower to expose the filter and the flow restrictor. If your hand shower is not equipped with a filter gasket, you should use one to protect your hand shower from the particulate.
Filter gaskets can be used at your body sprays and shower head as well if you have them. If you have a Hansgrohe thermostatic valve you don't need the little filter screens, because the valve is filtering the water good enough. We do not recommend opening your handshower for cleaning. There would be a strong chance you may not get it together again, or it may become damaged.
If your concern is with a buildup of lime on the spray faces, you can use a decalcifying agent to dissolve the deposits, but do not soak for more than 10 minutes and then rinse well with clear water.
Best regards,
Phil Heslep
Hansgrohe Technical Support
North America
Jan 08, 2012 | Home
My thermostatic concealed shower valve only gives either boiling hot water or cold water, there is no inbetween temperature? the cold is fed from mains and the hot from a combi boiler. the plumber has said...
If the hot and cold are fitted the wrong way round then the thermostat on the shower unit cannot operate properly!
Most thermostatic mixer showers have a 'bi-metallic' thermostat, if you supply the hot to the cold and vice versa IT WILL NOT WORK.
It is like wearing the left shoe on the right foot and the right on the left! It doesn't work.
Re-install the hot and cold to the correct supply, and this will sort it.
I hope this helps.
Jul 07, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Shower either runs cold or extremely hot
hi ya, if its a triton shower valve & only 2 years old it should have a 5 year guarantee, ring Triton & arrange a service call.
it sounds as though the filters could be blocked & more than likely the thermostat requires replacing as its more than likely scaled up?
You never mentioned where your based UK or abroad?
Kindly
Richie
Dec 15, 2008 | Home
Hansgrohe concealed thermostatic mixer ref no 1537418
check for sediment in your valve body... sometimes sediment can build up particularly in hot water pipes and that can cause the pressure balancing function of the valve to limit total hot water and therefore you cant get it hot enough... here is a link to what I think is the proper valve and the instructions for installing it... you'll want to follow the instructions for flushing and pressure testing... if you have good pressure at the thermo body then you might try adjusting the hot limit stop also covered in the document linked below...
http://www.hansgrohe-usa.com/JP/hrgh0264.pdf
Hope theat helps...
Oct 25, 2008 | Hansgrohe Plumbing
Home Logo
435 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
