Question about Epson Stylus Photo 1290 InkJet Printer
Epson 1290 Head Cleaning
I have a new Mac and consequently no software for my  five year old Epson 1290.  Do you know how I run the head cleaning utility using only the buttons on the printer?  I'd appreciate your advice.
Many thanks,
Tobias Davidson
Just download the software from Epson's site. I don't think there's anyway to run the utility from the buttons, I'm afraid.
Posted on Sep 18, 2008
I tried many times to unblock the jets using the cleaning utility, no good, I cleared the jets by inject warm water using a seringe directly into each pin in the head carrier, the printer response as it...
Hello.
After cleaning the heads with the warm water did you run the cleaning procedure through the printer again?? Cleaning the head with warm water is great, but you need to run the cleaning process after to prime the ink from the cartridge to the head. Also be sure to remove any Air-Hole stickers that may be on the cartridges.
I hope this helps Regards GM
May 28, 2011 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Black will not print, have tried cleaning head
The print head is probably blocked, its no good using the head cleaning option on the printer, you'll just waste ink.
There are several head cleaning solutions, fairly cheap on ebay.
Nov 23, 2010 | Epson Stylus Photo 1290 InkJet Printer
Won't reconize new ink cartridge rx680 printer
hi friend,
Run the Head Cleaning utility to clear any clogged ink nozzles. To run the Head Cleaning Utility, follow the instructions below.
For Windows users:
1) Make sure that your printer is ON and the error light is off.
2) Access the printer software.
3) Click the Utility tab, then click the Head Cleaning button.
4) Follow the on-screen instructions
5) When the power light stops flashing, click Print nozzle check pattern in the Head Cleaning dialog box to confirm that the head is clean and to reset the cleaning cycle
If you find that any segments are missing from the nozzle check pattern, you may need to repeat the head cleaning and print the pattern again.
Or u could consult the user manual
u should let the ink settle for 12-24 hrs???
hope this helps u
please rate me..........................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Hi my epson r285 with ciss is leaving ink blotches all over my print outs, predominantly black, but less frequent with the other colours. This is only a new printer. Head cleaning, noxzzle cleaning and...
It might be caused by waste ink at bottom plate around head sprayer. For some CISS (bottle) design, ink will flow to head, and then flow to pad, when printer off. So, you must close respiratory hole at bottle when printer is not used. For cleaning, turn off printer (unplug power) when head is not in parking position. Move head to center. Put wet tissue (with cleaner or hot water) at top of pad (at head cleaning mechanics). Move head to parking position. So bottom plate contact with tissue. Wait for 10 minutes, repeat 3 times. Check nozzle.
Jun 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
I can't seem to find a way to clean my Epson C60 ink nozzles. I'm running Mac OS 10.5.6 Thanks. -Bill Carter
Hi Bill
Go to the C60 online manual at:
http://support.epson-europe.com/onlineguides/en/sc60/index.htm
and select How To, Maintenance, Cleaning the Print Head.
This explains very well how to clean the print head etc using either the printer software or the printer control panel, for both Windows and the Mac.
Mar 15, 2009 | Apple Epson Stylus Color C60 InkJet...
My pictureMate 500 prints green only
Hi
Try running a head cleaning cycle from the maintenance menu, then print a nozzle check. try to run 3 head cleaning cycles then try printing again
. If all fails call epson for replacement.
Hope this helps
Nov 15, 2008 | Epson PictureMate 500 InkJet Photo Printer
Blue and sometimes red lines all across the prints using an epsom 1290. cleaned heads numerous times. nozzle check OK
Hey, sounds like the print heads, but replacing all the cartridges is best option first sometimes fixes the problem, if it dont you should look for epson 1290 cleaning cartridges on the internet they aint expensive, as head cleaning doesnt always unblock the print heads...
All the best
John
Jul 26, 2008 | Office Equipment & Supplies
Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Mar 07, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
511 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
