Question about Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch
Problem setting my timex iron man cr2025
I was trying to set my watch to the local time and have some how switched it off.I am unable to switch it on as i do not have a manual.please help me
  • 111 Answers
Good morning ! try to short the reset pad on the pcb of your watch ,just open the case back and use a twisser to short the reset pad ! good luck !....
Posted on Sep 04, 2008
I have a timex iron man watch. It jumps ahead 2 hours on occasion. Another time it jumped back 2 hours. what can I do?
There appear to be many versions of this watch. The first think I would check is the instruction book. It may be dual time zone? Amazon ca timex ironman Timex Watches
Sep 30, 2015 | Timex Ironman Watches
Hi I need to know: - 1. How to set the digital time? 2. How to switch on and switch off the alarm? 3. How to store telephone numbers? 4. How to set world time digital? In the world time what does DXB,...
DXB - Dubai
KBL - KabulKHI - KarachiDEL - DelhiDAC - DhakaRGN - Yangoon/RangoonBKK - BangkokHGK - Hong KongTYO - TokyoADL - AdelaideSYD - SydneyNOU - NoumeaWLG - WellingtonHNL - HonoluluANC - AnchorageLAX - Las Angeles (Airport)DEN - DenverCHI - ChicagoNYC - New York CityCCS - CaracasRIO - Rio de JaneiroLON - LondonPAR - ParisCAI - CairoJRS - JerusalemJED - JeddahTHR - Tehran
http://cyecorp.ro/dailylog/2012/01/07/cities-world-time-on-watches/
May 09, 2011 | Casio Twincept Databank ABX238BV Wrist...
Set time on TIMEX 1441 sports watch
To set your watch:
1. Press the top left button while the screen shows the time. The seconds should begin to flash on the screen. 2. Press the bottom left button to switch between seconds, minutes, etc. 3. To increase a number press the bottom right button 4. Press the top left button to stop changing/confirm the time you have set.
This is the general way to set most watches
Mar 30, 2011 | Timex Watches
I have set the 2nd time zone, but I can't set the watch to display the 2nd time zone.
Had the same problem when my niece was playing with my watch and switched time zones and I couldn't find the paperwork to switch it back. After not finding the solution online I played around with the watch and figured it out. Just hold down the start split button till it switch zones. It will beep when the switch completes.
Feb 24, 2011 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Change day but not date on Timex Expedition
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • THANK YOU
  • Jul 28, 2009 | Timex Expedition Outdoor Athletics Watch...
    How can i set digital time and alarm in the Timex wrist watch model is- MF13-Y-S7
    Try this ,it may work for you as i m having mf13-t1
    Press MODE then then SET
    Press ALARM to increase the count and to change time t1 or t2.
    Press MODE to switch the digit place
    finally press SET and then MODE
    Note: Check for bell and sound symbols,if they are not there
    Press MODE then then SET again press SET
    Press ALARM for once or twice depending on symbols.
    Mar 18, 2009 | Timex 27191 Wristwatch
    Why is my ironman draining my battery?
    Over time the circuitry in a watch can become worn and corroded.  This corrosion is usually barely noticeable.  More often, you won't be able to see much damage at all.  Nonetheless, the circuit is worn and is giving too much resistance to the battery.  This is cause the battery to pump too much voltage into the circuit just to run the watch.  This is draining your watch very quickly.  This is more common as the watch gets older.
    Jan 10, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
    I am not able to set the day on my times iron man 100 lap triathlon watch
    By the buttons there should be words like "adjust" or "mode", try pressing one of these dowan and holding for 4-5 seconds (no less) because sometimes it takes longer for the setting process to start. Once you get it to stat blinking press another button, one should be for moving the mode from seconds to minutes and another should be for the actuaul setting of the watch. When you find all that out , and set your watch just push the button you started with (the one that made it blink) and you should be good to go. PLEASE, if you still have problems, let me know. I will be glad to go over it with you on-line.Good Luck!!
    Aug 11, 2008 | Timex Watches
    Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch Logo
    1,125 people viewed this question
    Top Timex Watches Experts
    Ross Keen
    freddyfox
    Jerry Greenberg
    Jerry Greenberg
    Are you a Timex Watch Expert? Answer questions, earn points and help others
