Question about Sharp AL 1631 Copier
Problem with sharp AL-1540CS scanner
Can you tell me the steps to use scanner? ones I press scanner button it should display SC1 and it does not and scanner does not work ones I press the start button
  • Tim Babcock
    Tim Babcock May 11, 2010
    How are you scanning? Off the glass or using the software?
  • 62 Answers
Could be hardware or software problem. Try following steps in manual ; http://www.sharpusa.com/files/cop_man_ALCSOnlineManual.pdf, if that doesn't work, try scanning from a program, i.e. adobe instead of starting scanner from machine.
hope this helps.
Posted on Nov 02, 2008
What does L 1 mean on my Sharp AL-1540CS Also E 7. Help.
The L1 is for a scanner movement failure. The scanner bar that maoves back and forth under the glass is not moving as it should. The E7 is for a scanner lamp reference failure which CAN be caused by the scanner movement failure so I would try and resolve the L1 first. I have a tip posted here at Fixya that resolves the L1 so try that first and it may fix both problems. If not just comment on this and I will try and help you resolve any remaining issues.
Here is the link to the L1 solution:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 10, 2010 | Sharp AL-1540CS All-In-One Laser Printer
What does 4 H indicate?
When your copier voltage is abnormal then heater lamp is not on properly.So indicate H4.When H4 signal is blinking you must reset this code or error.
press c button press Photo/Exposure button again C Photo.(C>Photo>C>Photo) display blank press copy quantity button 14 press print key /Start key machine will be ready.
All are hopes fix
Dec 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Blinking h then 4
The error H and 4 blinking indicates that, You have a defective fuser unit.
H is for HEATER
You should replace youe heater unit, if your product falls in warranty period, you can avail wrranty..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Apr 10, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Scanner problem
Try uninstalling and reinstalling the scannner. Scanner's can be tough. Try disconnecting USB cable and reconnecting too. How recently did the scanner work? Try reinstalling the scanner software/driver. Also see if you can trouble shoot by right clicking on scanner icon from control panel, scanner.
repost if none of these work. thanks.
Sep 02, 2008 | Sharp AL 1631 Copier
Alternating 4 - h on a sharp al-1540cs copier
To perform the reset for the H4 do the following:
Find the Clear button on the Control Panel.
Find the Auto button.
Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
Then,
Press the [10's] key one time and the [1's] key four times to enter so the number '14' is in the LED Display, as if you were to make 14 copies.
Press the green [Start] button.
Press the [Clear] button two times.
The machine should now warm up and come to ready.
If the above steps do not clear the error code You may need to have a tech look at this.
Hope that helps...
Jun 26, 2008 | Sharp Office Equipment & Supplies
Printer drivers for Mac.
Goggle download program for Sharp AL-1540CS. This should take you to a site that will download the program for you. I recently got a new Vista computer and did this to hook up my old printer on it. It worked fine.
Good Luck
Jun 18, 2008 | Sharp AL-1540CS All-In-One Laser Printer
AL-1540CS error code F5
i have al-1540cs and it if flashing H then 4
Apr 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL-1540 CS Error
there is a lock on the left hand side ... make sure it is in the unlock position.
Mar 10, 2008 | Computers & Internet
Sharp AL- 1540cs
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Oct 19, 2007 | Sharp AL 1215 Black and White Copier
Sharp AL 1631 Copier Logo
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
