I set my Epson 3100z camera to manual mode and set up the camera for external flash. I manually set the shutter speed to 1/60 sec and the aperture to F4. I also set my SunPak flash to F4. My exposures seem pretty good. However when I review the various photo info's, the aperture reading is F5 or F4.8 not the F4 I set. Why is this? Anyone experienced this? The shutter speed are also not always what I set on the camera.
The aperature error is due to the fact that the lens in not a constant aperature design. The settings on the LCD are assuming you are at full wide angle setting. As this lens moves towards telephoto, the aperature changes about 2/3 of an f-stop due to the mechanical movement of the lens elements. So a manual setting of f4.0 at full telephoto will be more llike f5.0 in reality. It is too bad Epson could not make the mechanical aperature adjust to compensate, but every nice feature costs something.
I have not had any issue with the shutter speed changing. One guess is that the camera has shutter speed/aperature combinations that it can't achieve due to mechanical limitations, so it chooses the available combination. Another is that it wasn't in manual mode, but rather aperature priority mode and the final adjustments changed the speed.
Hello - having issue with Epsom R310 printer. Appears does not want to spool paper to print for me....
(More)
Hello - having issue with Epsom R310 printer. Appears does not want to spool paper to print for me. Have done nozzle check and it works ok then however seems doesn't want to do print jobhs. Message says to set paper properly and try again but won't work.
I have the Olympus SP-550UZ and need to replace the battery door. Anybody know how to do it or where...
(More)
I have the Olympus SP-550UZ and need to replace the battery door. Anybody know how to do it or where I can find instructions to do it myself. Thanks
I have the same broken door latch problem. Someone said they ordered a replacement battery door from...
(More)
I have the same broken door latch problem. Someone said they ordered a replacement battery door from Olympus, but when I called them they would not sell me the part directly to me. They said I would have to send the camera in to them for repair or use a repair shop that could order the part. It is highly annoying that they refuse to sell the part to the consumer! Has anyone else been able to purchase the battery door part directly? Thanks! Wendy
