Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
TV SONY KV-21FV10C7
Hello that tál, I will be you very grateful if you could help me in the following thing, I have a TV Sony Model color KV-21FV10C/7 and it doesn´t present audio, but their images (video) it is excellent, it doesn´t present problems, then, I carried out the following test: To the TV I installed him a team videograbadora and employ their antenna entrance and exit of this (video) I connected it to the entrance of TV, that is to say using IN: (To / V) of the TV and syntonized the TV in VIDEO and with all this I obtained the perfect audio in the TV (adjustable from the TV), then I thought that the tuner of the TV was bad or damaged, then I replaced it for one new and the TV continued with the same flaw (without audio), undoubtedly when ascending or to lower the control of volume this it leaves in the inferior bar of the TV. Now I have thought that their EEPROM desconfigurada (desprogram) that you think on this should be?, excusing that it bothers you with my problem, you am from already very grateful, cordially, Pablo Ugarte C. from Antofagasta, Chile E-mail: pauco17@hotmail.com
    Sergeant:
    Champion:
  • 318 Answers
The tuner has three components in it. rf video, audio and carrier, so your sound is not seen at the separation of signals.
1 inject an rf of 5.5 Mhz on the rf in put, if the audio path is good a tone will sound at the speaker. if you dont have a sound then you should tune a coil drum on the audio separator stage.
the 5.5 Mhz is off frequency.
try that.
thanks for asking fixya.
Posted on Feb 23, 2010
Sony kv-36fv27 color is bad.
Know to solders?Resolder ur video board socket holes that connected to( CRT tv Tube).Resolders the Yoke cable red, green,yellow connected to the main board also.Should get colors back,if the colors IC on the video in not dead,and capacitors help the IC on the video board.
Dec 19, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trintron Model # KV-27S22 Flashing screen
Hello
I got it fixed today at the TV repair shop down the street.
Thanks
Nov 11, 2008 | Sony HT-DDW840 System
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony KV-27S42 27" TV Problem
Hello BrianMcL
You are 100% correct, you will need a degaussing coil to take care of this problem. The instructions on how to use it will be included with the degaussing coil.
I hope this helps,
Thank you,
Shuttle83
Jul 06, 2008 | Sony KV-27S42 27" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Wega KV MOdel
hello, you may have a manual switch botton problem, check those volume control switch, do some test, check the board for some cold solder or short connection. ty
Nov 19, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
For Sony KV-1415WR problem
Hiii...
First :
what chassis your tv set have ?
#2 : Where exactly the location of D608 ?
#3 : How may time the LED Blinking ? like we all know Sony have selft diagnostic with it ?!
I hope hear from you soon...
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Oct 08, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No color
If the settings are correct and the signal is good but there is no color, it can only be one of 2 things - the CXA jungle IC and the chroma crystal next to it. If you have never replaced small parts on PC boards then have a qualified tech handle it for you.
Aug 09, 2007 | Sony KV-35S45 35" TV
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
