Question about Mercury PVCLE266 Motherboard
Output to monitor
I am facing an hardware problem.there's no signal being transmitted to the monitor unit
No signal
Posted on Sep 06, 2008
  • 797 Answers
Hello macks_11:
I need more information about the problem.
You can have a bunch of things which are having problems.
monitor cable and or connectors on the monitor or on the computer.
Check your monitor with another monitor.
Make sure the cable connectors are not damaged such as bent pins.
If all that checks okay, then you need to look at the computer.
Test the video output on the computer.
Make sure the video in the control panes/system is working.
Make sure that the monitor is detected in the system. Some monitors will not turn on unless it is correctly detected and setup in the system. They should still work at the bios boot, though.
I am kind of guessing around, and hope that something here is a help to you,
take care,
Posted on Sep 02, 2008
How solve in my POLYCOM VSX 6000 showing error "unsupported signal adjust your PC output"
Try using the S-Video output and then try using the VGA output from the VSX 6000 unit. The unit can be fixed to output from either as the first monitor output (you may have the dual monitor option enabled). If this does not work the resolution of the TV might be HD, the output of your VSX 6000 is Standard Definition. You will need a monitor that accepts standard definition. If this does not work, I would reboot your VSX 6000 and try again. David
May 17, 2014 | Polycom VSX 6000 (220022222001) Video...
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
Sep 09, 2008 | M-Audio Audiophile 192 Sound Card
10 Tips for the PSK31 Digital Mode
PSK31 is arguably the most popular amateur radio
digital mode. It utilized phase-shift-keying to
provide robust, narrow signal width communications,
and requires very little power to QSO the world!
- Use the center of your waterfall. Testing will
show that your transmit (TX) and receive (RX)
will be strongest there. Don’t blindly use 1000Hz
tone or strictly follow the VFO ‘set it and forget it'
concept. You can easily lose 20% or more of
your power on each edge of your pass band.
Pass band centering of the signal will give the
best results of both RX and TX.
-There's no need to have the waterfall streaking
bright red. Set your rig's volume to a low level
(less than 25% of max) and adjust your waterfall
and soundcard levels for a good contrast. Do not
overdrive your soundcard! Get the background
noise and the transmit trace well defined and
separate. Keep in mind, how your waterfall looks
does not impact decoding, but it is harder to work
it if you can’t see it.
- Use UPPER CASE characters sparingly. Lower
case text in PSK31 varicode transmits fewer bits
of data, thus you'll increase transmit speed and
improve the likelihood of proper decoding on the
other end. For example, the difference of a
lowercase e and an uppercase E is five times
more bits! (e=11 vs. E=1101101101)
- Enable your RF Attenuation and increase the
volume. This helps keep a strong signal from
wiping out the weaker ones. Attenuation will
probably be around 20 dB, but by dropping the
noise level, the signal readability improves. AGC
(auto gain control) does nothing for a weak
signal; it only levels the louder ones.
- Use your digital modes software, or a program
like Spectrogram, to see what you noise level is
with the radio off. This will give you an idea of
how 'clean' your soundcard is. Typically,
onboard (built-in) sound hardware (as found in
most 'mainstream' computers like Dell or HP)
does not have a signal-to-noise ratio as good as
an inexpensive (less than $50) separate
soundcard. When purchasing a soundcard, look
for something with over 100 signal-to-noise ratio
in the specifications.
- Consider dual monitors (most modern video
cards have two jacks). This allows you to have
the waterfall or spectrum display on one screen,
and your logger, text window, etc. on the other. It
makes a huge difference in speed and ease-ofuse
when you don't have to swap between
screens or use smaller windows for your QSO.
- Keep your ALC reading during transmit to as
close to zero as possible. This will keep your
signal clean and your IMD at a good level (-20s
or better is ideal). Your power output will drop,
but there's no need to 'smoke' the transmit level.
PSK31 is about an 80% duty cycle. Even with a
full duty cycle rig, it still needs to dissipate heat!
Besides, 20 watts more makes little difference.
Output of around 50W is enough to work the
world, and your fellow CQs will appreciate the
courtesy. Also be sure your voice processor is
NOT enabling when using digital modes.
- Ask for an RSQ (readability, strength, quality)
report! When in a QSO, send just a tone and ask
for your IMD and a report on how your trace
looks. This will give you a better idea of
adjustments needed.
- There are hundreds of digital modes. To get
started or to learn more about the most common
ones, acquire ARRL’s ‘HF digital handbook’ by
Steve Ford, WB8IMY. For the technical types, be
sure to snag Roland Prosch’s (DF3LZ) ‘Technical
Handbook for Radio Monitoring’.
- Try 30 meters PSK31! It’s a robust band, offering
the best of 20M and 40M. It’s a small segment of
a no contesting band. Used only for digital
modes and CW. Be sure to operate within your
privileges. PSK31 can typically be found around
AGC (Auto Gain Control): The ability to reduce
signal strength on-the-fly (fast or slow), giving you a
more level audio reception on stronger stations.
ALC (Auto Level Control): A voltage adjustment or
reading, indicating your TX signal levels . ALC is
designed to control voice and carrier signal levels,
not digital modes. Typically, if the ALC meter moves,
then the microphone gain is too high.
Signal-to-noise (S/N) ratio: A comparison of the
signal levels to the relative noise level. Ideally, a
perfect signal would have no noise, but realistically,
you’ll want a S/N ratio well within the tolerances of
the mode you’re using. PSK31 tolerates about a
10dB S/N ratio.
dB: Sound level, or ‘decibels’ are used to measure
the relative strength of a signal.
Digital Mode: A converted signal transmitted from
your radio to be ‘de-converted’ by the receiving
station. Much like a computer modem, a digital feed
is converted to analog, sent across a transmission
medium, then reconverted back to a readable signal
at the receiving station.
Duty cycle: The total time of actual transmission
levels. When your radio is transmitting, there’s an
on/off process that takes place. Transmitting at a
100% duty-cycle indicates that your are using 100%
of your radio’s power, 100% of the time. Better
radios will allow this, while others will eventually fail
under the pressure of such a load.
IMD (Intermodulation Distortion): The ratio, in dB,
used to determine the quality of your transmission.
Unwanted ‘products’ or signals reduces IMD levels.
More power does not mean better copy!
Overdrive: Turning the volume of your radio up so
high that you risk damage to the soundcard, or cause
signal ‘splatter’. Similar to maintaining your ALC
Pass band: The range that your transceiver can
receive when on a single frequency. Typically
around 3000Hz wide.
PSK (Phase Shift Keying): A form of modulation
that shifts the transmit signal in order to carry more
information. PSK31: is a digital mode created in the
1990’s by Peter Martinez (G3PLX) that is about 31Hz
wide on your waterfall.
RF (Radio Frequency) Attenuation: A suppression
of signals received. You’ll often see a noise level
reduction, with a minor sacrifice to the desired signal
reception. Check your radio’s manual on how to
adjust it.
RSQ (Readability, Strength, Quality): Much like the
familiar ’RST’ reports, using a 599-type reporting
scheme. Instead of ‘Tone’ (Morse Code), use
’Quality’. 95%+ readable, with a very strong waterfall
trace, and a clean (no splatter) signal would warrant
a 599 report.
Soundcard: A piece of hardware in your computer
that produces sound, and often allows input, as with
a microphone.
VFO (Variable Frequency Oscillator): It’s that knob
you use to change frequencies on your radio.
Varicode: A streamlined coding system that allows
nearly whatever your computer keyboard can type to
be transmitted in shorter lengths.
Waterfall: A visual display of radio signals (and other
sounds) found on the tuned frequency.
ARRL’s ’HF Digital Handbook’,
by Steve Ford, WB8IMY
‘Technical Handbook for Radio Monitoring I’,
Digital Master 780, by Simon Brown, HB9DRV
Spectrogram and other software:
on Apr 28, 2010 | Audio Players & Recorders
A2dp pairing problems
The Victsing unit states that it is a receiver. This will receive the wireless signal from a device and output sound through the headphone jack. A bluetooth transmitter would input sound into the headphone jack from your tv or other source and transmit the signal over bluetooth to a paired receiver. Two of the same type of unit will not pair with each other.
May 10, 2014 | Victsing New White Black Bluetooth A2DP...
I have a Sony DAV-HDX275 Theater System that I'm trying to connect to an old 17 LCD Dell Monitor. The cable I have is a HDMI to DVI connector. My monitor will pick to the digital signal but nothing appears...
This is because it is transmitting an compressed encrypted signal and the monitor is made to recieve uncompressed signals,You can sometime get around this by changing the output to vga or analog on the theater system.
Aug 25, 2010 | Sony BRAVIA DAVHDX275 Theater System
Abs light on accord 1992
ABS control unit recognizes system related problems and causes ABS warning light to come on and stay on under any of following conditions:
  • ABS pump runs longer than 2 minutes.
  • Vehicle is driven with parking brake on longer than 30 seconds.
  • One rear wheel is locked.
  • Wheel speed sensor does not transmit a signal.
  • Vehicle is driven on extremely rough road.
  • Low battery voltage.
  • Operation time of solenoid valves exceeds a specified value and control unit indicates an open circuit in solenoid circuit.
  • Output signals from control unit are not transmitted to solenoid valves.
  • Temporary loss of traction due to excessive cornering speed or starting from stuck condition (mud, snow or sand).
Nov 19, 2009 | 1992 Honda Accord
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Cannot get second monitor output to work on ATI Radeon X1200
A DVI-D signal is digital (whereas DVi-I is digital AND analogue) and can never be converted into a VGA signal without using expensive hardware boxes that convert the signal. These though tend to lose quite a bit of the signal quality. If I were you I'd look for a monitor with a digital connection, because I'm afraid this isn't going to work.
I'm sorry your problem can't be fixed...
@DickcanFixit: Catalyst 9.4 is the most recent.
May 30, 2009 | ATI RADEON Graphic Card
No sound
What kind of monitor is it? What kind of sound is it?
Many companies will let you access and print out their manuals for free online if you input your model and make on their website. Search under "manuals".
Also, the HP w22 LCD I have has internal speakers whose settings and volume levels are controlled through the buttons on the front bottom of the monitor. The monitor has a 'PC Audio In' jack on the back side, which is used to input the digital signal from the back 'audio output' jack of the computer desktop. This HAS to be plugged in with a specific audio cable to power (transmit the digital signal to) the internal speakers.
Check your settings for your external speakers by clicking on 'control panel', then 'hardware', then 'speakers' (IF your computer has located them, meaning that they're plugged in with their driver downloaded). You should be able to configure the speakers and test them for sound.
Windows may have a 'volume mixer' on your taskbar that controls the levels of your Windows application sounds, your device (speaker) sounds, and the Media Player(s).
Dec 11, 2008 | Computers & Internet
Panasonic multi display feature
I am not shure if the tv's are capable of multi display features. I know that some of the tv's are capable of showing multiple pictures on the same screen.
Usually the signal is sent to 1 panel and the out from that panel and into the next panel and so forth unit they all have a signal.
Dec 26, 2007 | Panasonic TH-42PHD8UK 42 in. Plasma...
Mercury PVCLE266 Motherboard Logo
55 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
