Question about Krups Small Appliances Espresso Machine
Krups XP7240 - leaking
My machine goes through all the motions of making coffee but spills clear water from the apeture forward of the drip tray. What is the cure
Denis D
  • denma Oct 13, 2008
    Further to comment re KrupsXP7240 leaking from from a vent in the base. The machine goes through all the motions for a coffee except the required measure of water pours out the bottom. The machine is 9 months old. The last actin I carried out was cleaning the driptray. I wonder if I lost a part?
    Genius:
  • 1,239 Answers
HI Here are some of the most common problems that can cause your drip coffee maker to stop working:
  • The power cord or on/off switch can go bad. In either of these cases, it's best to get a pro to replace it or buy a new coffee maker -- replacing it improperly can lead to a fire.
  • The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick.
    • The tubes can get clogged with calcium. This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
Posted on Oct 13, 2008
    Master:
  • 505 Answers
You need to make sure that both the Lid and the steam tub is clean. Also make sure that there are fitted properly. If the problem is still there you need to replace the steam tub and the lid both.
Thanks
    Sergeant:
    Champion:
  • 435 Answers
Could you please tell us the steps you did to get into this problem.
May be we can diagonize if we know it.
Thanks, :)
  • 39 Answers
Did you clean the poors of the resivore? if not use viniger and make shure you run it 3 times after.
  • 4,472 Answers
First off how long have you owned the unit and when did this problem develop. Once I have more information I can assist you further.
Thanks,
Lee
Error 06
Look for a water leak, it may be to the base of the machine and will release out the vent UNDER the drip tray if you tilt the machine forwards. There are many places for it to leak, not easy to find, I have an outer housing with cutouts to allow me to see inside while it's running. Hydraulic ram and the distributor are the most common places to cause error 6 but there is also a tricky one where the valve on the pump releases to the drip tray. A leak is the problem, finding where/which is the hard part.
Nov 29, 2013 | Krups XP7245
I had some water problems with mij krups and try to solve it. Now it gives an error 0D. What does this mean?
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Feb 11, 2011 | Krups XP7245
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
I have a problem with my Krups XP7240, it is
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
May 10, 2010 | Krups Small Appliances Espresso Machine
My xp7240 has also started leaking water from beneath the machine
the distribuitor as down!
its dificult to substitute. maybe find an expert its a good option for this case.
Jul 02, 2009 | Krups Small Appliances Espresso Machine
Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
Krups XP2070 coffee machine - new - espresso side - water goes straight into the drip tray & not thru the filter.
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Aug 03, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
May 19, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Small Appliances Espresso Machine Logo
506 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
