Question about GE APN10AA Portable Air Conditioner
Leaks and must be drained every half hour
I shampooed my carpet about two weeks ago and again a week ago. Believe me it was necessary. Since then my A/C seems to be producing in excess of 6 gallons of water every 12 hours. I have to drain it every 20 minutes while in use or it will create a puddle which soaks my carpet so that it feels like a sponge. I have to drain and turn it off when I sleep or wake up to a mess. This thing produces so much water I could easily water a garden.
It's probably my fault, but how long will I have to wait for it to return to normal opperation?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
A user said its doing what its suppose to do ,remove moisture, and you do have to empty the bucket atleast 5-times a day or night, and the automatic shutoff shutsoff when you need it most, so he wnt to a window unit and have' not looked back since!
Posted on Sep 02, 2008
A/C drain pipe needs constant blowing out
I think you have a leaking drain, sorry.
Sep 20, 2016 | Heating & Cooling
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
How often should I bathe my dog?
It is recommended that you bathe your dog at least once every three months. If your dog spends a lot of time outdoors, I would suggest bathing them more frequently.
Aug 15, 2012 | Pets - Others
I need instructions on how to use my machine. Can you please help!
if its a bissell,go to bissel .com and request a manual sent to you.there should b a cartridge that you push a button to unlock so u can fill it with water or carpet shampoo.I fill mine half water half carpet shampoo. then u put it back on ,make sure it either clicks or snaps on.plug in and turn on,they usually have a button that turns that say wash or rinse.it depends on your machine.
Jan 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Coolant Fluid leaking, Car was stalling out, Now wont start.
I believe, you have a head gasket problem,the coolant ,go to the cylinder,I wish ,that not happen ,good luck
May 28, 2009 | 1985 Volkswagen GTI
Whirlpool refrigerator w/ top freeezer
It has a plugged defrost drain. You may need to defrost for 24 hours with unit unplugged and doors open. UNPLUG FIRST!! f still leaks, you need to remove floor of freezer, then the back wall of freezer. Remove ice. At center rear under coils is the drain hole that is plugged up. Use hair dryer to melt ice. Pour hot water in this area to uncover drain. With hot water in area, you can put a 1/4 diam. hose or copper pipe in drain and blow into it while pressing down. It will slowly go through ice, clearing drain.
Nov 17, 2007 | Whirlpool ER6AHKXPQ Top Freezer...
GE APN10AA Portable Air Conditioner Logo
210 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
