Question about Cameras
I have an AIPTEK camera and every time I try to use it it freezes. Is it broken forever or is there a way I can fix it? I got it from target to be honest, which probably wasn't the best choice. The battery is fully charged by the way. It's model is DZO-V58N. Please help.
Don't bother to send it to Aiptek for repair.
I sent them my Pencam 1.3SD camera. They kept it for 2 months. Every time I sent a email asking if they had repaired it, the email reply was always the same.....
" Chris " is working on it !
I finally received it, and you guessed it. It wasn't working !!!
Yesterday, I opened it up, and repaired that fault in about 20 seconds.
Posted on Sep 02, 2008
Aiptek model DZO-V58N firmware upgrade
Did you try a web search and see what comes up for this model ?
Jan 26, 2013 | Aiptek Pocket DV2 Digital Camera
Tip
OMGosh the damn thing worked after hitting it a few times. Wow thanks soooo much...
Surprisingly enough, most freezing problems (and other problems, too) can be solved by gently hitting your camera. It works! Just remember to be gentle.
on Jul 05, 2008 | Konica Minolta DiMAGE G400 Digital Camera
My aiptek digitil camera lcd is broken, iwant to replace it.. pls. where can i go to repair this.
If the LCD is broken you must first get the price for the LCD unit before you think of changing the unit. If the price is high compared to the price of the camera, then you must think of exchanging the camera.
The LCD must be sourced from the service center.
Jun 29, 2011 | Aiptek Cameras
Aiptek IS-DV Memory Full message when memory card is empty
Exactly the same thing happend to me with my brand-new Aiptek. Turns out it was the no-name brand SD card that I got from China which destroyed it. Aiptek was kind enough to replace it for free since it was under warranty. Aiptek's caution: Stick to brands like SanDisk, Dane-Elec, Kingston, Transcend or PNY. Purchase from resellers like Target, Best Buy, Newegg.com or Amazon.com. Avoid MINI & MACRO style cards. NO Sandisk Ultra II or Extreme III, class 6. AVOID Hi-SPEED!
Feb 12, 2009 | Aiptek PVR Camcorder
Every time i insert the memory card my camera freezes up and i have to take the batteries out in order to get it to cut off or function until i remove the card.
plug your camera, with card inserted, into your pc and run a scandisk to it.. Right click the drive and then properties, then scan disk. Select fix all and let it run. If that doent work, then try a new card. They are very inexpencive now adays.
Dec 21, 2008 | Aiptek ISDV2.4 Flash Media Camcorder
Dv8800 aiptek
You have to have device drivers loaded to use as a web camera. If you go into my computer does it see your computer as a web camera as well as a storage device?
Jul 05, 2008 | Aiptek DV8800 Digital Camera
File failed
Mine is freezing up as well and then the file filed...help!
Feb 29, 2008 | Aiptek DV8800 Digital Camera
Will not recognize 16 GB SDHC Card - Help Please
I had a literally terrifying experience with Aiptek customer service.
I called up Aiptek to ask if it was possible to get my memory cards working. I have two 4GB SDHC PNY cards, which th ekid at target reccomended after loking at the back of the box.
I was told by aiptek tech support that PNY cards will not work in the A-HD camera.
When I mentioned that the box says it will take cards up to 32GB, and asked him if this was not false advertising. The representative became irate and started insulting me, using valgure language, and calling me a liar.
At this point I had enough of his abuse and yelled at him F.U!
What happened next is Truly Absurd and Outrageous!
The man behind the telephone at Aiptek told me he was going to send 5 guys to my house to assult me and my fammily!
THIS IS NO JOKE!
Jan 19, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Transferring mp3 files from memory card onto computer
Those multifunction devices require several drivers. I assume you loaded the drivers onto the computer. It sounds like you are using a memory card that already has MP3 files on it. That may be a problem if the camera or software is expecting to see the files in a certain folder on the card. Try uploading MP3 files to the camera and then see if you can move it back to the computer. Since you just got it, check and see how much time you have to return it to the store. If you have a bit of time, check out the help section of Aiptek's website. http://www.aiptek.com
Sep 11, 2005 | Aiptek PocketCam DV4500 Digital Camera
Cameras Logo
147 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
