Question about Saeco Incanto Classic Espresso Machine
Water does not blend with coffee
I recently opened my Saeco Incanto Rondo in order to fix a problem with the grinder, I managed to fix it and to put everyrthing back in place However, when I push to button to make a cup of coffee, the only thing I get is grinded coffe beans. There is no espresso coming out - instead there are rinded beans in all three trays on the inside. The machine is able to make steam, but it seems that the water flow is not activated during the brewing process. Please help!
  • birkeboy Sep 02, 2008
    Thank you very much for your help. I really appreciate it. I have now opened the machine again and I am now trying to make the red dots to fit together. However, the problem is that there are fixed position on the lower part of the grinder which makes it impossible to fit in the wheel in the lower part as it is not possible to move those fastenings. What can I do?
  • birkeboy Sep 05, 2008
    Thank you, it is working again!
  • 515 Answers
When you mount the grinder back, do you turn it so the red mark fit together?
Try to check the brewing unit, on the top off the brewing unit you will see a little pin. Take it out and make sure this is clean and put it back again.
Posted on Sep 02, 2008
  • Mirko Blas
    Mirko Blas Sep 04, 2008
    Hi Eric,
    You have to press the adjustment pin down to turn the parts.
    Let me know if you get your machine to work again.
    Best regards
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Ave an SAECO INCANTO RONDA with milling problems.
You can turn the grinder (mill) so the plates open for a more gross coffee this will help the grinder motor to rotate more free you can use a vacume cleaner to **** all the remainig coffee inside the grinder. If still not any reaction you have to desasemble complete clean the grinding plates. If you still not have any reaction then the grinder motor burn out and need to bee replaced.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
I have a Saeco Incanto Rondo with a grinder related problem
First step.If the grind is to coarse the burrs will spin to fast sensing no beans.
Solution: The grind needs to be finer. Caution you can over adjust causing the clay burrs to shatter.
Gold Roast Coffee
Jun 14, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
We have an Saeco Incanto Rondo sClass. When brew coffee, only about half of the water goes through the brew group and the rest goes into the drip tray. When we try to run steam or water through the wand,...
My SAECO coffee machine is a real disappiontment. We frothed the milk a few times and then the machine started to only warm the milk and provide a small amount of froth. Now the company is trying to tell me it's something I am doing! Not so. It is the expensive machine not working.
Makes three shots and that's it.
Is there a bypass setup on the pump, or have you checked the capacitor on the machine.
Mar 26, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Saeco Incanto
how tight is the coffee packed in the dripper, the flow rate is determine by how tight the coffee is, thats why you always see the barista press the coffee against the disk of the grinder dispenser in a coffee store
Jul 06, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
260 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
