Question about Insignia NS- 27" TV27 TV
Power Board I think it is power board there is any way i can fix it.
  • ravi118 Sep 03, 2008
    i can not find service center in canada
    Guru:
  • 1,894 Answers
You can fix it. note down the model number of the unit, also if possible take the units power board along with you to the service center and get a new one form them.
since you are a electrician i think i need to give you much details about handling electricity ..
thank you
Posted on Sep 03, 2008
Samsung TV Makes Clicking Sound and Won't Turn On
Did you repair the power on power off switch I think that would be the only item needing replacing
I once had this same issue and went replacing the power supply board
Mine ended up only needing the power switch replaced so I got to return the board and put the old one in
Usually if you give the old board up when buying a new one a generous amount of money is taken off the new board price and this is done for any and all boards I have ever replaced in any item
I would try to see if you fixed the issue with your new board if not try the power switch that should fix the problem for less money
Oct 26, 2017 | Samsung Televison & Video
How to fix LG 47LN5200 TV?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 30, 2015 | LG Televison & Video
LG 47 LS 4500 LED LCD burnt power board
Hi Keith,
First try to replace your power cable if it seperate from your TV and use another power socket to cofirm your cable is good and power socket. If your power cable is attached to the TV then just take the set to repaire centre and get it fixed.
Regards
Ashwin
Jan 23, 2015 | LG Televison & Video
Is a 473603d/27 phillip power supply board compadible to a 473063d/f7 power supply board
More than likely the old board just a, or a few, blow, capacitor(s). It you have a soldering iron, you can replace them yourself for just a couple of dollars.
Just look for puffed-up little can-shaped thingies, unsolder them, and buy replacements for a buck or two down at Radio Shack, and you should be "good to go"!
Easy fix, and cheaper than a replacement board.
I would think the /f7 board would work, if it has the same connectors as the /27 power supply board.
Jul 26, 2014 | Philips 47PFL3603D LCD TV
Sony KDL-46SL140 Power Supply Board
If you're sound in electronics, you can surf through and get the voltages to different terminals of the power board. If you wish to get more details, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option. It has service help details to many brand televisions.
Jul 06, 2013 | Sony BRAVIA® KDL46SL140/91 46 in. HDTV LCD...
The power only stays on for one second, then turns off.
think you need new caps on power supply board.......
.easy fix if you can use a soldering iron....
or look on ebay for replacement power supply board..........
cheers
Apr 08, 2011 | Hitachi Televison & Video
Tv Prima lv-2628p dead Big spark under power supply part # mip 260b if i change the board do you think willbe fixe
Most likely that will fix the problem ,replace the power supply module,usually the board that the ac line cord plugs into,good luck
Mar 01, 2011 | Televison & Video
My Samsung LN-t4671F LCD TV clicks for about two
You are having another problem with the power board...there are some capacitors which are easily replaced to cave you the cost of the board. If you are technical,I can guide you further,other wise a reputable shop can fix this very reasonably
Jun 07, 2010 | Samsung LN-T4665F 46 in. LCD Television
Warreny over , fix it myself ?
I don't think you'll be completely happy with this, but I'm pretty sure the DC Jack (the power plug you broke) is soldered onto the power control board. This doesn't mean it's not repairable. I've done this with some good success in the past, but you might just want to replace this entire "daughter" board. HERE'S ONE on eBay for about $75, a lot less than the $200 for the mainboard or more for a complete replacement or repair. You could try to repair the DC jack and if that $12 fix fails, replace the entire Power Control Board (PCB). I think you should take it apart and check at least. It isn't that difficult if you have patience and the right tools. You'll need a "computer" or "electronics" screw driver kit and something like a credit card to help pry apart plastic pieces without scratching them. I also found this thread on NotebookReview that talks about doing what you want to. To see what the board looks like check out these pictures: eBay: 3680 mobo1 http://i17.ebayimg.com/04/i/001/0d/e1/7ce9_1.JPG To pick up the DC Jack you'll need, check out eBay, they are around $12 shipped. HERE'S ONE EXAMPLE GOOD LUCK!
Oct 07, 2008 | Acer Aspire 3680 Laptop
TV repair person told me my Toshiba 50HP16 Main Power Supply Circuit Board is bad as well as a secondart board. How do I identify these boards and get part numbers? Its too expensive to have the repair...
Even if you buy the parts you may get sticker shock!!! Why did it need a power supply and another board. Will your set come on? I may be able to give you part numbers but you need to be specific about which other board you think you need such as X Y signal board or power supply Some single circuit boards for some sets are as high as 600 bucks hope not for you
Sep 19, 2008 | Televison & Video
Insignia NS- 27" TV27 TV Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
