Question about Kenwood KAC-5201 Car Audio Amplifier
Kenwood kac-5201 amp
There is nothing happening when i wire it all up no light ,sound. Can you help with me with this problem please may have wired it up wrong
    Champion:
  • 232 Answers
12 VOLT FROM THE BATTERY SOURCE GOES TO 12VOLT BATT CONNECTION.12 VOLT GROUND RETURN MUST BE FIXED TO THE FRAME OF THE VEHICLE.SOME VEHICLES HAVE FACTORY GROUNDS UP HIGH ON THE SIDES OF MOST VEHICLES, U CAN USE THIS GROUND LOCATION. IF CONNECT REMOTE WIRE FROM THE RADIOS REMOTE TURN ON LEAD WHICH IS A BLUE/WHITE WIRE OR A STANDARD BLUE IF ITS JUST ONE BLUE WIRE. CONNECT THIS LEAD TO THE REMOTE TURN ON CONNECTION ON THE AMP , SOME KENWOODS HAVE TWO ,INPUT AND OUTPUT LEADS.U ALSO NEED A TEST LIGHT, OR U CAN USE A SPEAKER TO TEST FOR POWER AT UR CONNECTION.IF U USE A TEST LIGHT , CLAMP THE END U WOULD GROUND TO THE VEHICLE, TO THE AMPS GROUND, THEN TOUCH THE PROBE END OF THE TEST LIGHT TO UR WIRED CONNECTION TO VERIFY U HAVE POWER AND GROUND TO YOUR CONNECTION.IF TEST LIGHT DOESN'T WORK ,CHECK UR FUSE AND REMOTE TURN OR LEADS.
Posted on Sep 02, 2008
My light on my Kenwood Kac-8103D amp is constantly on red and nothing is coming out? How do I fix this
Check your fuse. Also make sure all your wiring and terminals are correct and not loose.
Dec 11, 2011 | Kenwood KAC-8103D Car Audio Amplifier
How do i get this amp to workin an Oldsmobile Intrigue with a factory radio?
you need a hi-lo adapter and that hooks up to the right or left rear speaker then the remote wire needs to go behind the deck to the ignition wire. if the system is pre amp then you have to bypass the amp system
Aug 03, 2010 | Kenwood KAC-5201 Car Audio Amplifier
My Kenwood KAC 9152D Amp is hooked up to power and wont turn on.No light no nothing. Power going to it is good though.
Check your ground. Make sure you sand off any paint where you grounded the amp. Also did you hook up the remote wire? It's the blue wire on the back of your headunit. Some say remote wire, others say power antenna either one will work. Sounds like one of the two...hope this helps.
Mar 28, 2010 | Kenwood KAC-9152D Car Audio Amplifier
The red light on my kenwood stereo amp KAC-628 will not turn on. I was wondering which wire is causing this to happen?
the power wire or the remote wire check ur fuse in ur power wire if thats good check your connection to the battery if thats all good its ur remote wire located in the back of ur head unit
Mar 16, 2010 | Kenwood KAC-628 Car Audio Amplifier
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
A red light is flashing
On the top? is it your power protection light?
May 26, 2009 | Kenwood KAC-5201 Car Audio Amplifier
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Apr 14, 2009 | Kenwood Car Audio & Video
Instalation
Everything is possible around here! http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69 http://www.jigsawmanual.com/manuals/mfg/kenwood/kenwood_kac_kac5201.html Good luck :)
Jul 03, 2007 | Kenwood KAC-5201 Car Audio Amplifier
Kenwood KAC-5201 Car Audio Amplifier Logo
261 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
