Help An Idiot at my work pressed the bluetooth button on the bottom of my bluetooth mouse and now the mouse doesn't work. I called a computer company to help me and they told me to press the keyboard bluetooth button..even though the keyboard was working fine! I;ve done that and now both the keyboard and mouse arn't working......HELP!!!
  • jmay88 Sep 05, 2008
    It's all good i've solved my own problem... Thanks for trying though
    President:
  • 2,712 Answers
If yours is a Logitech mouse+k/b, try the following link:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=7709
If not, please post back with the make and model of the mouse and k/b..
Posted on Sep 04, 2008
How do I start the pairing process on the mouse?
plug in NANO to usb port then press the connect button on the bottom of mouse ,with it turned on of curse .
Jun 13, 2015 | HDE Ergonomic Bluetooth Wireless Optical...
My hp wireless optical mouse stopped working, even with new batteries. please provide a DETAILED step-by-step process for resetting it. i know it involves pressing buttons on the bottom of the mouse and...
namastey!
*clean the bottom of a mouse and if the lens gets dirty wipe it with the soft dampened cloth
* replace the batteries
*Reinstall wireless drivers. If your mouse came with a CD, re-insert it into your computer's disc drive and install all software and drivers.Disable internal transceiver. If your wireless mouse connects to an internal Bluetooth transceiver, disable it using the Bluetooth utility in the Control Panel, and then re-enable it after a few minutes. Then try connecting your wireless mouse.
Aug 22, 2011 | HP Wireless Optical Mouse
The wireless keyboard and mouse are not working.
  • Check to ensure that the wireless receiver is plugged into your computer. Press the "Connect" button on the bottom of the receiver to attempt reconnecting your mouse and keyboard to the computer. If your mouse and keyboard use Bluetooth, ensure that your computer's Bluetooth is active and detects the mouse and keyboard.
  • Check to see if the keyboard and mouse are turned on. If the power indicator lights on the keyboard and mouse are not green, press the "Power" button to turn the keyboard and mouse on.
  • Check the batteries of the mouse and keyboard. If the batteries are dead, replace them with fresh batteries and reconnect the mouse and keyboard to the computer by pressing the "Connect" button on the bottom of the wireless receiver attached to the computer. If your mouse and keyboard use rechargeable batteries, let the batteries recharge before using the device again.
  • Uninstall and reinstall your wireless keyboard and mouse drivers. Sometimes, the Logitech drivers are at fault for a bad connection. Use the Control Panel to uninstall the old drivers, then visit the Logitech website and install the latest drivers for your keyboard and mouse.
  • Search the Logitech Support Database. If your keyboard and mouse are still failing to function properly, visit the Logitech Support website and browse the support page for your product for specific solutions.
Feb 04, 2011 | Logitech Computers & Internet
I have an hp wireless mouse, and it doesn´t work!! Tried everything...
Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this could help you a lot..:-) Thanks..
Dec 27, 2009 | HP Wireless Optical Mouse
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Mouse stopped working..changed the batteries..was working, now it
on your computer screen at the bottom right corner, there should be a bluetooth icon (if your mouse is a bluetooth mouse) right click the bluetooth icon select ADD a device. after that follow the prompts, at some point it will ask you to have the bluetooth device be discoverable, which means you have to press the bluetooth sync button at the bottom of the mouse, if it blinks then you can proceed connecting or syncing the device. hit me back with the results.
Jan 29, 2009 | GE Wireless Optical Mouse
Bluetooth keyboard and mouse not working with computer
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 09, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
XPS One Keyboard's Characters not functioning
Try to re-sync the keyboard to the computer. Here’s the procedure:
1) Turn the computer on.
2) Turn on the keyboard
3) Press the sync button on the rear of your computer’s left speaker.
4) Press the sync button on the keyboard. ( I believe it’s on the bottom of keyboard)
The sync button has a symbol next to it, (2 arrows going in clockwise direction).
Ensure that the keyboard battery has not run low.
If that doesn’t work, look for a Bluetooth icon in the lower right hand corner of your desktop and double click on it to open the Bluetooth configuration utility. See if there’s a configuration file for the keyboard. If there is, delete it and then re-detect Bluetooth devices.
Hope this helps.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 20, 2008 | Dell Inspiron XPS Gaming Mouse Pad KU170
Logitech keyboard quit working
hi,
almost every wireless keyboard / mouse has a connect button somewhere. its located on the bottom or on the side. what you need to do is to press and hold on the connect button to synch the device with the transmitter connected to the computer. if the transmitter on the computer has a connect button you might need to press them both at the same time. do the same if the wireless mouse stops working.
Oct 16, 2008 | Logitech Cordless Desktop MX 3000...
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
