Question about Nokia 2100 Cellular Phone
Contact service i've been using the phone for 5 years.i changed the battery last year. on the screen it shows CONTACT SERVICE. i cannot even switch off.what shall i do?
    Genius:
  • 1,673 Answers
The microcontroler area may have a failure, or the internal firmware may be corrupted. The phone will require factory level service. Sometimes a defective SD card can cause function problems.
It may be cheaper for you to change the phone if this is the case.
Jerry G.
Posted on Nov 25, 2008
How can I have someone help with a problem about seller preformance other then customer service
eBay has made some changes in this . They now will remove some low detailed seller ratings. eBay has made some improvements on ""seller protection"".
eBay
Feb 21, 2012 | eBay Auctions
I have nokia 5130c2 purchased on last year it complete 1 year 2 months now when i made a call bateery show empty and switch off otherwise battery i made full before this
Try by changing a new battery.
And see it happen again or not?
In case if it happen again than it's a hardware problem.
So you need to go to the nearest Mobile Service Centre for repairing/sorting
Thanks for Using FixYa All the Best!
Jul 28, 2011 | Nokia 5130 Cellular Phone
Dear Brother, I have nokia 3110c from about 03 year ,yesterday my mobile suddenly switch off then ON ,then i saw contacts in phone memory not showing even phone memory showing 15% its mean contact in...
try visiting this web site "repair-mobiles.com/3110c-contact-service-problem/" and follow the instructions given. These are also some pictoral descriptions if they would help.
Mar 16, 2011 | Computers & Internet
After 7 years working properly, the event button has stopped working. There is no way to start the load in manual, or to change the program... What can I do?
You posted under EH40 Intermatic programmable timer.
EH40 Manual:
http://waterheatertimer.org/pdf/eh40-manual.pdf
1) EH40 uses size A battery. Replace battery.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#Battery
2) Reset the timer: Press and hold reset button for several seconds
3) Contact Intermatic because they are aware of specific problems with specific timers
http://www.intermatic.com/customer%20service.aspx
4) Other folk have reported EH40 and EH10 last about 3 years.
EH40 has 1 year limited warranty.
I test timers: 7 years is reasonable run for inexpensive electronic time switch.
5) For longer lasting timer, consider Next Generation: battery is replaced every 8 years
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 28, 2011 | Intermatic EH40 - Electronic Water Heater...
Hai, I'm using W960i since last 2 years, since the bignning it is hanging, especialy when i'm trying to open the addrees book (Contacts) or files in the Memory (built in 8GB). I already reinstall OS,...
hi
then there must be an error functioning of the hardware in your mobile.. don't give over load to your phone . this will affect your performance of your mobile.. contact your service provider to find your problem they will find the fault in your mobile.. and they will change the component in your phone.
thank you
Dec 25, 2010 | Sony Ericsson W960i Cellular Phone
NOKIA 5130XPRESSMUSIC SHOWING SERVICE CONTACT ON SCREEN
NOKIA 5130XPRESSMUSIC SHOWING SERVICE CONTACT PLEASE SOLVE MY PROBLEM
Mar 07, 2010 | Nokia 5130 Cellular Phone
Canon A710IS Battery Drains Quickly
I have this issue as well, the camera seems to drain the batteries even when it is not on.
Oct 07, 2009 | Canon PowerShot A710 IS Digital Camera
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Nokia 2626 contact service
SOLUTION NOKIA 2626 CONTACTE SERVICE
Jan 27, 2008 | Cell Phones
Nokia 2100 Cellular Phone Logo
78 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
