Question about Sony SA-WM20 Subwoofer
HOOKING UP THE SONY SA-WM20 TO AN AUDIOPHILE PREAMP
I am connecting two (2 channel) speakers to the SA-WM20 subwoofer. There is an input terminal above the speaker connections to the subwoofer. What should be connected to that terminal?
I am trying to connect the subwoofer (cable tv, plasma and dvd player) to my conrad johnson SA120 amplifier and PV10BL preamp which only has the following rear inputs: main out, tape out, tape in, aux 2, video, cd, tuner and aux1/ph. It's a bit confusing since the sony dvd player has the three (red/white/blue) rca jack hookup. Can anyone lend a hand to this audiophile novice? Much appreciated, Carlos.
  • salsaslugger Sep 02, 2008
    Great visuals, thank you!
  • 2,071 Answers
How can i connect my subwoffer to my preamp (mark levinson 38)
You can't hook it up to your preamp. If the sub has speaker level inputs you would use them to hook it up to your amp speaker terminals. The left positive and negative goes to the corresponding left positive and negative at the amplifier and the same for the right channel.
Nov 13, 2015 | Kenwood SW36HT Subwoofer
I have a sony sub model sa-wm20 will it work with this mini system
Read the manual.
http://www.retrevo.com/support/Sony-SA-WM20-Subwoofers-manual/id/752ag408/t/2/
You would use the Speaker Terminal hookup option. Your front speakers would attach to the sub's speaker terminals.
May 02, 2011 | Sony MHC-881 Shelf System
How do i hook up the wires from and to a sa wms 315 subwoofer
what r you hooking it to is #1 rca wires r the way to go when hooking up a subwoofer up .some subwoofers have 2 rcas on them one input and one output the in put is mono if what your going to hook it to has rcas on it then the left one is a mono output but if its an audio system then it mit have a subwoofer output on it
Jun 29, 2010 | Sony SA-VA1 Rear Speaker
Can i hook a sony sa-wm20 subwoofer to a Sony DV435.53X
Yes.....simply connect the High Level Imputs to the output of the amplifier of your system.
Jun 02, 2010 | Sony SA-WM20 Subwoofer
I just go a sony sa-wm20 sub woofer and i dont know what cable goes where it says input which one do i get and where from?
Um, its hard to understand you, but to my understanding you don't know which is positive and which is negative... Striped= Positive, bold= Negative, or Red= Positive, black =Negative. Lastly + positive - negative
Dec 13, 2009 | Sony SA-WM20 Subwoofer
Can i hook up my SA-WM20 subwoofer to my sony DAV-S500 home theater
As long as your sony reciever has a sub out connection you should be able too. This powered sub you have has a rca sub input which should coincide with the receivers rca sub out.
Aug 04, 2009 | Sony SA-WM20 Subwoofer
Denon / MK Sub Hookup
you can do this one of two ways, you can use just the left "mono" on your sub or use a y connector. If the sub doesn't show the left as mono then YES you need a y cable
Apr 10, 2009 | Sony SA-WM20 Subwoofer
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
How to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Oct 05, 2007 | CTG 2 ft. Stranded Wire Crossover Cable...
Sony SA-WM20 Subwoofer Logo
997 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
