Question about Canon Optura 60 Mini DV Digital Camcorder
Camcorder Kindly tell me the diff between all the camcorders available? Which is a appropriate one to buy as per the points below? 1. versatile. 2. easy to use. 3. high res recording.4. good recording time. 5. good battery run time. 6. value for money. 7. less maintenance cost. 8. semi-professional. 9. handy in size. 10. somewhat weather proof. 11. where the video is easily transferable to other media( computer,projector etc) Regards. dpkt
  • dpkt Sep 02, 2008
    Thank you gowerboy very appropriate advice
    Problem Solver:
  • 15 Answers
Books have been written on this subject. The easy answer is go to a reputable camera store rather than an electronics store, tell them what you want to do with your camera and they will suggest models that suit you. All camcorders are now digital but some record on tape, some on a hard drive or DVD and some on memory cards. Those using tape don't have to compress the image so much and give better pictures. Normal digital video is quite good enough for an amateur, but high definition cameras are becoming cheaper. All cameras have sockets to transfer the recording to computers or other media or even play the recording direct to a television. Most recorded video benefits from transferring it to a computer, using an editing program, adding titles and burning it to a DVD. That way your friends will want to see your work more than once.
Finally, again I say - go to a camera store on a quiet day with plenty of time to listen to their advice. You'll learn more than anyone can tell you in an answer here.
Posted on Sep 02, 2008
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
4bbl marine carb Holley list80328
The fuel needs to shut off about 1/4 of an inch below the level of the join between the top and base of the carb ,this is a old mechanics proviso like 4th per inch diameter of the bore for piston ring gaps (water cooled engines) and setting up a diff unit with a wiggle woggle .Unlike todays mechanics who if no OBDII plug they are lost let alone know about carbs and points
Jul 05, 2013 | Cars & Trucks
When gas is press engine lacks power it only goes 40 miles per hour or below
This can be one of many possibilities - either electrical, fuel or exhaust.
Your vehicle's Onboard Diagnostic system will identify the culprit, so have your system checked to extract the code/s.
However, if you can't get the codes, I would suspect the following possible faults:
1) Throttle Position Sensor (TPS) - this tells the engine computer 'how far' you are depressing the accelerator pedal. Then engine computer then tells the EFI to respond accordingly.
2) Vacuum Leak - if you noticed the problem gradually getting worse, it's possible small vacuum leak has progressed to the point your EFI system cannot respond properly.
Without querying your vehicle's computer, I personally would suspect the TPS. You can measure the the readings of the TPS using a multimeter - check it is to manufacturer's specifications.
Cheers,
"If this has helped you in any way, please rate this solution or kindly recommend this post"
May 13, 2011 | 2002 GMC Envoy
How to create logo design?
Hi,Your logo is your business face to the world. Make a lasting impression with a custom logo designed by the experts and they combine your vision with clever design, guiding you through the entire process. Your Dream Design Team logo will be:
1. Original: A one-of-a-kind visual identity that expresses your business' unique value or style.
2. Identifiable: Instantly recognizable and memorable to new and future customers.
3. Engaging: Simple, yet powerful design elements, colors, and fonts combine to create your brand.
You can try here http://www.xnynz.com/xyz/logo-dream-design/
Apr 18, 2011 | Computers & Internet
How to restore computer to an earllier date?
To restore your computer, kindly navigate to the below steps
Through the All Programs menu:
  • 1.Click Start.
  • 2.Point to All Programs.
  • 3.Point to Accessories.
  • 4.Point to System Tools.
  • 5.Click System Restore.
Choose the appropriate date of restore and select system restore.
Oct 12, 2010 | Computers & Internet
This camcorder does not record video; it won't format memory card
do you get any kind of error code?what type of memory stick are you using?how big is the ms capacity?may need to try using a diff ms or try using ms with diff devices.if diff ms works fine.may need to format ms using computer first (using card reader if available) and camcorder last.may need to reset camcorder (make sure cam is on when you press the reset button.hope this works.thanks :)
Mar 12, 2010 | Sony Handycam HDR-CX12 Flash Media...
I haven't used it in a couple of years, it's in excellant condition I think, but it has a code flashing and I am unsure what to do.
That's what I will try and do. Here's what we need to do:
Sony® camcorders nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current camcorder models can only be returned to the original factory settings by pressing a small RESET button on the camcorder.
Older-model camcorders (prior to the year 2000) do not have a built-in rechargeable battery or RESET button, and require a manual power reset.
IMPORTANT: To determine whether or not your camcorder has a RESET button, or if model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camcorder.
Using a RESET button
  1. Locate the RESET button on the camcorder.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camcorder.
  2. Disconnect AC power adapter.
  3. Remove the battery pack.
  4. Remove the lithium button-cell battery.
  5. Move the POWER switch to the CAMERA position for 15 seconds.
  6. Move the POWER switch to the OFF position.
  7. Reinsert the lithium button-cell battery.
  8. Reconnect the AC power adapter or reinsert the battery pack.
  9. Turn on the camcorder.
If your camcorder is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Let me know how it turns out.
For more info on the trouble codes, look here:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C79466&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=92061592&stateId=0%200%2092065814
Apr 26, 2009 | Cameras
Blow Gun Specs
Specifications for air blow guns include pressure capacity and air line connection type. Pressure capacity or maximum rated pressure is rated at the air inlet and measured in pounds per square inch (psi). Many types of air line connectors are available. Quick-release connectors contain fittings that are attached internally. By contrast, push-on connectors include barbed ferrules. Air blow guns use several types of national pipe thread (NPT) connectors, most of which are inch-based and female. Important NPT measurements include threads per inch (TPI) and outside diameter (OD). 1/8” NPT connectors have 27 TPI and an OD of 0.405”. 1/4” NPT connectors have 18 TPI and an OD of 0.540”. 3/8” NPT connectors also have 18 TPI, but an OD of 0.675”. 1/2” connectors have 14 TPI and an OD of 0.840”. #10-32 NPT threads are also available. Air line connections that can swivel or pivot are suitable for applications that require versatile positioning.
Aug 27, 2008 | Astro Pneumatic AP 1718 Deluxe Air Blow...
Programming channels
Hello ... IF YOU HAVE A COMPUTER YOU CAN MAKE PROGREMING, DETETINMG AND TRUNKING A BREEZE. IF NOT I FOUND THAT ALL FIRE AND POLICE TRUNKING ACTIVITIES ARE BETWEEN 840.0000 through 900.0000. WHEN YOU WANT TO SAVE A CHANEL TURN OFF RADIO AND TURN BACK ON SELECT THE DESIRED CHANNEL YOU WANT. THEN PRESS "PGM" AND ENTER YOUR FREQERNCY... PRESS ENTER AND IF YOU WANT TO ADD ANOTHER CAHANNEL ... HIT "PGM" AGAIN AND FREQ. AND ENTER. YOU CAN KEEP DOING THIS TILL YOUR DONE GROGRAMING .. THEN JUST HIT SCAN AND IT WILL SCAN ALL THE FREQ.S YOU HAVE ENTERED. HERE IS A SOFTWARE PROGRAM THAT CAN LOOK UP ALL FRQ ANYWHERE IN THE US AND WITHE A PLUGIN DOWN LOAD ALL THE CHANNELS. BuTel software home page ARC-433 software for Radioshack PRO-433 / PRO-528 / PRO-2051 'ARC433 is now available!' -------------------------------------------------------------------------------- ARC433 (US$ 29.95) is dedicated software for the RadioShack PRO433, PRO528 and PRO-2051 and is the most versatile software available for the Radio-shack PRO-433 / PRO-528 / PRo-2051. Screenshot from our memory editor: the most versatile memory editor available on the market: -------------------------------------------------------------------------------- Overview of options in ARC433: Order ARC433 now online using PayPal/credit card or call Santa at 1-800-SCANNER ARC433 supports the Radioshack PRO433, PRO528 and PRO2051 models in one single software package. ARC433 includes THE most versatile memory editor available on the market. Radioreference.com import option for conventional and trunk systems! Programming your scanner was never this easy! Enhanced CSV file import and 'mapper' Paste Frequencies DIRECTLY from any website using 'Paste Special' Setup channels in an easy, spreadsheet type interface. User Manual (45 pages, PDF file) Store Unlimited number of configurations on your harddisk. Copy/Move/Swap memory banks / memory channels Compatible with Windows 2000 / XP. All updates are free for registered users Easy cut/copy/paste data between channels and banks. Move channels up and down with quick move buttons Export CSV data Fill down/series option Full clipboard support for import/export data to/from other applications Easy data toggle with mouse double click or space bar or keyboard shortcuts Sort frequencies per bank Remove duplicate frequencies Easy Fill for setting up new banks in a few seconds (enter a start frequency and a step, and easyfill will calculate and fill the selected bank) Extra Dummy bank for storing temporary data while you are re-organizing your scanner channels. Print option System Requirements: Windows XP/2000/Vista PC interface cable 20-047 for USB or PC interface cable 20-289 for serial port Use other cables at your own risk! Use the ARC433 demo version to verify communication works before purchasing the software! All software sales are final. Order ARC433 for PRO 433 / 528 now online using PayPal or a credit card or call 1-800-SCANNER. -------------------------------------------------------------------------------- Screenshots:
Apr 16, 2007 | Radio Shack Pro-95 Handheld Scanner
Connection using Firewire
Use a DV cable to connect the camcorder to the computer. Determine whether your computer has a 4-pin or a 6-pin DV terminal. Use an appropriate, commercially available DV cable for your computer's DV terminal. When making this connection, the use of the compact power adapter is recommended. How to connect ? 1. Turn the camcorder's POWER switch to . ? 2. Move the TAPE/CARD switch to . ? 3. Connect the computer's DV terminal and the camcorder's DV terminal with the DV cable as shown in the image below. The location of DV terminals differs between computers. For more information, please refer to the documentation that came with your computer. Important: 1. Operation may not work correctly depending on the software and the specifications/settings of your computer. 2. If the computer freezes while the camcorder is connected, disconnect and reconnect the DV cable. If the problem persists, do as follows. (1) Disconnect the DV cable, and then turn off the camcorder and the computer. (2) Turn the camcorder and the computer back on and reconnect them with the DV cable. 3. The image files saved on the hard disk drive of your computer are original data files. If you wish to edit these image files on your computer, make copies of them first, and use the copied file, retaining the original.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Canon Optura 60 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
