Question about SanDisk Sansa e260 MP3 Player
How do i enter usb 2.0 mode and how do i download the updater
I need help entering usb2.0 mode and im only 15 so i need the most simple explanation i can get and why when i try downloadin the sansa up dater it says this can only be launched by sansa service It says 2 enter USB 2.0 MSD mode. I dnt kno wat 2 do. Is it because im doing it on my laptop? I tried many times 2 c if it wud work. Y isn't it workin? Am i doin sumthin wrong? I need help
  • 758 Answers
Go under menu, settings and click on usb mode..
there should msc mode and thats what you want it to be
I hope that helps
Please rate accordingly
Computerrep
Posted on Sep 02, 2008
When i power it up it is reading at the top of the screen load main image failed switch to recovery mode then it just freezes
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......recovery mode lock the sansa hold center button in and push and hold the start/menu button until recovery mode....Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Dec 21, 2010 | SanDisk Sansa e260 MP3 Player
My mp3 is froze and i tried to reset but it want
hold the switch for 15 seconds. the same thing just happened to me.
Dec 22, 2009 | SanDisk Sansa Fuze MP3 Player
I turn it on and the screen is white.
when that happen to me i held the power button and the middle button at the same time for like 15 sec then it turned off  try that  then turn it back on
Nov 09, 2009 | SanDisk Sansa Fuze MP3 Player
How do i get the driver of the mp3 so that it gets recognized on my computer?
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Oct 26, 2009 | SanDisk Sansa e260 MP3 Player
I was trying to download the sansa media converter so could put pictures on my sansa e260 and im getting an eror installing iKernal.exe(0xa00) not sure how to continue
Also make sure you are connected to a 2.0 usb the back of the computer2.gif is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Oct 25, 2009 | SanDisk Sansa e260 MP3 Player
I hav a sansa e260 player it was working just fine until recently the screen is just blank and only the ring glows .my pc doesnt recognize the device please help
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard2.gif).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Set sansa to recovery mode, Start the updater plug the sansa into the computer, unplug when told sansa, should restart (Lock sansa press and hold rec and menu until recovery begins)
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Go to my computer click on folder scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders Right click on your sansa then format a couple of times hope this works
Oct 22, 2009 | SanDisk Sansa e260 MP3 Player
Blank Screen, Frozen, restarts FAT Error message
hold switch up for 15 seconds, this will reset the dam thing
Oct 04, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa latest updates
SANSA E260 ENTER USB 2.0 MSD MODE
if you go into the setting section of the menu you can select the USB mode back again, if this fails to solve the problem, take the back of the player off via 4 very small phillips screws and remove the battery for at least 30 seconds then put it back in and it should be good.
Mar 21, 2009 | SanDisk Sansa e260 MP3 Player
your pc will; if it's reasonably new, have USB 2.0 ports and that is probably what you need to connect the player to for transfering files, it's not a mode thats within the player that you can change, it may work with usb 1.1 if it does it will just transfer at a slower speed that's all, if it's a laptop thats about 4 years old it should have USB 2.0 ports, but some dont show, that goes for both pc and laptop, so try connecting in a different port to see if it connects. The Sansa updater will probably only be used when there are updates available and will be automatically advised when you are on line.
Jun 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
90 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
