Question about Alpine MRV-F545 Car Audio Amplifier
MRV-F545 VLT Error
Hi, I am having a problem with my Alpine MRV-F545 Displaying "VLT" error. I've checked wiring, grounding, subwiring, and battery. When my vehicle is on the volts displayed on amp when checked says 13.8V. I am stumped and not sure what more to do. Any ideas on what to do will be great.
  • Anonymous Jan 27, 2009
    I HAD SAME PROBLEM COST ME $220 NZD
    SOMETHING HAD BLOWN INSIDE THEY SAID I HAD SPILT SOME THING
    ON IT SO I HAD NOT !!! BUT I STILL HAD TO PAY
SOURCE: VLT Error
chenge battery
Posted on Sep 29, 2007
Shuttle83
  • 1139 Answers
SOURCE: Alpine MRV-F345 VLT ERROR
This is an indication of a voltage error, I have seen this when the voltage regulator or the car battery is begining to have a problem supplying enough current to the amplifier. Check the voltage levels with the amp turned off and then turn on the amplifier, if the voltage drops this means that there is poor voltage regulation and this may mean that you will have to replace the car's voltage regulator.
I hope this helps,
Thank you,
Shuttle83
Posted on Apr 22, 2008
  • 631 Answers
SOURCE: Alpine MRV-1507 "low Voltage"
If it indicates that you have an open shield ground, read through the following page. It will show you how to test the shield ground connection of your head unit..
Temporary RCA Shield Repair
Posted on Aug 17, 2008
etirbynnor
  • 655 Answers
SOURCE: MY AMP KEEPS BLOWIN THE FUSE...i CHANGED THE
Hello creelb22,
Fuses usually blow because of a short of too much current.
Test your wiring (including the speaker wires) and make sure they are not shorting or grounding against the vehicle chassis. Also make sure that the speaker voice coils are not shorted.
Hope this helps.
Posted on Jul 26, 2009
  • 55 Answers
SOURCE: alpine mrv-f545 powers up but no power going to the channels
I suppose you checked all the usual suspects? Fuse, Ground, and Remote turn on?
Now if memory serves me isn't that an amp that has a digital display on the top? If so you have to scroll thru the menu items and see if it is on low pass or even off? The gains are tricky because they get louder with less dbs. but check the outputs.
if all else fails it's probalby bad.
Posted on Sep 01, 2009
Alpine 345 amp flashes VLT
If the fault occurs even with the engine switched off , there is no reason of excess voltage but if the inverter DC-DC convertor within is faulty it can cause this error.
You can remove the covers and check for any visible signs of capacitor leak or burning. Unless the circuits are isolated the fault cannot be traced or confirmed. It can be a short in any of the regulators or drivers but has to be confirmed.
Dec 23, 2011 | Alpine Car Audio & Video
Amp
I honestly don't have a solid answer for you. I can say check your fuses. Check your battery to amp wire. And also check your ground. Make sure the fuse on your amp is also not blown
Feb 26, 2010 | Alpine MRV-1507 Car Audio Amplifier
Alpine mrv-f345 cuts off when...
Yes sounds like your not getting enuff power from the battery could be your alternator you should have it tested. Also have you try'd a capacitor? I put one in my car and it stopped cutting out...
Feb 05, 2010 | Alpine MRV-F345 Car Audio Amplifier
Alpine mrv-f545 powers up but no power going to the channels
Mar 16, 2009 | Alpine MRV-F545 Car Audio Amplifier
Aug 14, 2008 | Alpine MRV-1507 Car Audio Amplifier
I hope this helps,
Thank you,
Shuttle83
Apr 20, 2008 | Car Audio & Video
Sony kv-16gw1
I would suggest that you get a schematic for this device and the examine the power supply section with a multimeter.
Sep 07, 2007 | Alpine MRV-F545 Car Audio Amplifier
No power to amp
soundsto melike an underrated ground system. make sure that your ground cable is clean and is connected to the frame.
Sep 02, 2007 | Alpine MRV-F545 Car Audio Amplifier
Alpine V12 MRV-T707
power wire from fuse block goes to "the 1 that says power"...remote is used to have your device turn another device on...like a cd changer
May 28, 2007 | Alpine MRV-T707 Car Audio Amplifier
Alpine MRV-F545 Car Audio Amplifier Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
