Question about Kenmore 22062 Top Load Washer
Kenmore front loader
The soap, bleach and fabric softner are not draining. They seem clogged. Any ideas on how to fix?
Thanks,
Julie
  • 639 Answers
There are little holes for the liquid to release form in the cups.
Check that the holes are not clogged!
Posted on Sep 02, 2008
Fabric conditioner not going down
Fabric conditioner does not always go down, maybe you have a blockage on soap drawer, This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jun 03, 2012 | Whirlpool Washing Machines
I have a Kenmore Elite front loading washer model 110.42922. It approximately 5 years old. The fabric softener dispense and the bleach dispenser are no longer working. Any Ideas?
Sounds like the lines are clogged.Soap and softener leave residue that over time will build up and clog the machine.It is not hard to fix but it does take a while.I would try very hot water first,just pour it down the dispenser.If that wont clear it.Take the cabinet apart and find the clog then remove it.The lines are transparent .Also while you are in there,look for a small electric motor,which pumps the bleach to the tub.If the lines are not clogged,replacement of that motor is the next step.Most probably it is just dirty.
May 15, 2011 | Kenmore Washing Machines
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Smelly front loader washing machine. Clothes come out smelly too. How did I fix the problem???
You may have to do this 2 times and you will never find this in any manual. Use 1/4 cup "Powdered" Dishwashing soap and 1 cup of bleach in an empty tub cycle. Run a load of older dark clothes or non flammable rags FIRST after doing this the first time. If they come out with streaks run the cycle of 1/4 cup Powdered dishwashing soap and 1 cup bleach again. Same routine after 2nd cleaning cycle... dark clothes check for anything out of the ordinary. You should not have to do it a 3rd time unless your machine is really gunked up. Hopefully your using HE type soaps in your front loader. Non HE laundry soaps will cause the smelly machine also.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Washing Machines
FABRIC SOFTNER DISPENSER NOT DRAINING
you can try putting a dishwashing tablet in it with some hot water and let it sit overnight ...the tablet has something in it made to desolve build up for water ,soap,ect...and it safe to the washer and to you too.I used one in my water drain on a water in the door ice box worked like a charm.
Dec 03, 2009 | Kenmore Washing Machines
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Fabric Softner section won't fully drain....
Aug 14, 2007 | LG WM2688HWM TROMM SteamWasher
Washer not always draining
It sounds like you have a couple of things going on here. First of all, the most common problems associated with a poor drain on a washer is due to clogs in the pump and/or drain hose. But first, make sure you don't have your drain hose shoved down in the drain standpipe too far. If you don't leave an air gap for the drain hose, this will often cause poor drainage problems and/or siphoning of the water as it tries to fill (this may be a cause for your soapy clothes, too). The drain hose should rest inside the standpipe so that pipe is not sealed and the hose is not sitting in the drain trap. You can check your drainage also by connecting a wet/dry shop vac to the drain hose and try to pull water through it from the machine. There will be some residual water that remains in the tub after washing. Just follow these simple steps: 1. Unplug machine. 2. Remove the lower kick plate under the door. There will be a screw in the bottom corners of the panel holding it on. 3. Find the drain pump. It will be on the right-hand side and is usually white in color. The drain hose from the bottom of the tub will be connected to it. 4. Remove drain hose from standpipe and connect a wet/dry shop vac (if you have one) to the end of it. 5. Turn vacuum on and watch the drain hoses from the tub and from the pump. If the hoses collapse, you have a clog somewhere. 6. Remove the drain hose leading to the pump. Check the impeller area of the pump for debris. This is usually where coins, clothing labels and other items get caught. 7. Clean out the pump and drain hoses. 8. When finished, reconnect any drain hoses that you previously removed making sure you get a good seal with the hose clamp BEFORE you fill the machine. If you notice a leak during fill, hit the "CANCEL" button to stop. Make sure you place the drain hose back in the standpipe too. Now...dispenser problems are usually the result of fabric softener and mildew. If you remove the dispenser tray from the machine and look inside the compartment on the front of the washer, you will notice a series of small holes in the overhead portion of the cavity. This is where water gets dispensed into the tray and flushes softener, bleach and detergent into your wash. If these holes get clogged, the tray will not dispense properly. Take a rag and clean this area thoroughly using some hot water. The water will need to be warm enough the melt any fabric softener residue that may have accumulated over time. Next, clean the area really good with some bleach solution to get rid of any mildew. You may have to use something to clear all the holes of debris. Often fabric softener is the culprit and it cakes the holes up. A simple wiping down with a rag may not be enough to do it. A cotton swap of tooth pick works great at cleaning these holes. This is also a good time to take the dispenser tray and soak it in some hot water in the kitchen sink to clean it out as well. Good luck to you and let me know if you find this advice helpful.
Aug 13, 2007 | Kenmore 43142 Front Load Washer
Kenmore 22062 Top Load Washer Logo
62 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
