Question about Alpine MRV-1507 Car Audio Amplifier
The Amp Power Light Coming ON and staying red.
Ok i have a mrv1507 alpine 1000 watt amp and i recently went out for a while and when i checked it, the red power light is on and its not blinking its a solid red light and i checked every thing... I think there's something wrong with the amp but i took it apart nothing looks messed up but it is electrical so could b internal but i was wondering is it junk bc of this or is there any way i can fix it or what becuase it went out then came back on a couple times then never came back on.... SO if u can help ME i would ty ALOT..
Maybe it needs more voltage to it?
Posted on Nov 01, 2008
    Genius:
  • 1,550 Answers
Your amplifier are on protection mode,maybe the audio amplifier IC´s are in bad conditions
Posted on Sep 05, 2008
I have a 300 watt alpine 4 channel amp powering 4 x 6.5" kenwood speakers. My speakers can take up to 170 watts each. I have to turn my gain up all the way on my amp in order to get a quality bass...
Your amp is overheating as your speakers all combined are 680 watts, double your max output on your amp. Ideally you need a 1000 watt amp to do the job and for perfect sound as you should never have your amp up to max as it is more likely to blow quicker. The 2000 watt amp your are speaking of will do the job perfect, but you need to keep the gain down around 50% as you could blow your speakers. But yeah all together you are right, the 2000 watt amp will stay cool as doesnt have to work nowhere near as hard as the one you have currently.
Mar 02, 2011 | Alpine Car Audio & Video
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
I just got a sony xplod 1000 watt amp i got everything hooked up and when i turned the key the power light chaned from green to red. i check over the amp again and again, i cant find any thing wrong........
Try disconecting all speakers from the amp, turn it on after and if it stays on red it sounds like it had kicked the bucket. if it stays green start from their and check all of your wires for shorts (speaker wires) again. hope this helps...
May 08, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
Amp makes noise. I am purchaseing a new amp
Hello termite440,
A mono amp will generally provide more power for subs. And for those Audiobahn's, you'll want something that will provide a minimum of 500-600 watts RMS to each, a least a 1000 watt amp. At the low end, something like the Alpine MRP-M1000 or the Orion HCCA-D2400 will provide 1000-1200 watts. I'd recommend the Alpine. For more power, and another $100, look at the Alpine M2000, or for another $250, the Rockford-Fosgate T1500-1bd.
Hope this helps.
Apr 28, 2009 | JVC KS-AX5500 Car Audio Amplifier
Mrv1507 power light blinks red..
Your speakers probably are made for 6 or 8 ohms. to check, take out any of the speakers and read the back for the ohm rating, if it is more ohms, you need a more powerful amp.
Jun 18, 2008 | Alpine MRV-1507 Car Audio Amplifier
Sony xplode 1000 watt amp
Make sure you don't have a short circuit somewhere. Make sure the wiring is all intact.
Also look at this link:
http://www.fixya.com/support/t132850-sony_xplod_1000_watt_car_amp_quit
Mike
Nov 07, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Alpine amp and subs questions
it will depend on how you use the 2 alpine subs,, do you know what there individual impedance is [ ohms ] and how you intend on wiring them,,,in series, in parallel, in any case you must maintain the min load in order to load the amplifier properly,,,otherwise the amplifier will operate improperly and allow DC [ direct current ] to pass and fry your subs...so what I really need is more in formation
Jul 15, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Car Audio & Video Logo
426 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
