Question about Mitsubishi WS-65869 65" Rear Projection Television
Mitsubishi TV Model #ws65869 Blinking Green light
After a power outage the TV would not turn on. The green timer light blinks all of the time when the unit is plugged in. The reset button, nor any of the buttons on the TV or the remote control have any effect on the TV.
Can you help me with this issue.
  • bdotn Mar 01, 2009
    Actually, mine is the 55869. After power outage. Same blinking green light. I read all the posts, went to Radio Shack, bought 1000/35 capacitors... plus de-solder, and solder and put new ones on the DM board.... uess What ?? same blink green light.... Replacing the IC may be beyond my skills ... that IC looks really tiny. I assume by IC you mean the IC9B00. where can I get one of those ? Should I just send the board to someone to repair ? Thanks.
  • 928 Answers
Sorry for the late reply I just got up.
From what I understand of your problem it is most likely a blown capacitor or main IC. Unless I can open up the unit and test the IC's and capacitors I can not be really sure which is why I hardly answer questions about TV''s as they are hard to troubleshoot without the unit in front of you. Ive found a site that can help you via a service manual since I could not find the exact service manual for you from my manual book. The site also has the parts that you will need if ever im right and it is the capacitor or IC. As for the IC's by experience is hard to test without an Oscope but you can do it by gradually eliminating the problem, again you will have to refer to the service manual regarding that. By the way the capacitors I mean is the one that goes to the main module as that is what powers the controls for the TV. the green light is just the "pilot light" which means you have power to the TV but the power is not going past the capacitors to the main controls or the main IC. So simply put the problem can be the capacitors (Which is what you check first) if they are ok then look at the IC via using a service manual. You can use a multitester for the capacitor first if they are dead then just change them and you should be ok. Let me know what happens or updates ill reply to them as well.
Posted on Sep 02, 2008
I have a mitsubishi 73' tv..we ordered a bulb but that wasn't the problem..,we have power and sound..the code light blinks really 6 times and yellow 1..can't find a code to match that,
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 14, 2017 | Mitsubishi Televison & Video
LF501EM5F LED HDMI flat screen tv blinks red light 4 times & no picture but back lights work
http://electro-medical.blogspot.com/
Jan 14, 2017 | Televison & Video
Blinking green power light on WD65737 for a minute or so then shut down, Will also go to welcome screen and then shut down
Jan 13, 2017 | Mitsubishi WD65737 65 inch DLP 1080p HDTV
TOSHIBA MODEL 32RV530U WILL NOT TURN ON YELLOW LIGHT IN FRONT BLINKS 3 TIMES
This could very well be a problem with the power supply not allowing the TVs to start up but can also be caused by a problem with the TVs firmware. I would suggest downloading the firmware and following the steps from the following link. The download and steps are in the firmware tab after clicking the link. Be sure that even if you have no picture while applying the firmware update that you under no circumstances remove power from tv for at least 15mins. This is to ensure the firmware completely loads. If you remove power while it's still updating the board may be corrupted. http://support.toshiba.ca/support/ceg/center/en/index.asp?p=32RV530U
Jan 13, 2017 | Toshiba REGZA 32RV530U LCD TV
I have a Sony kds-60A2020 with no sound or picture two green and 7 red errors code
Jan 12, 2017 | Sony Televison & Video
MY dstv DSDD 1132 decoder is flashing red and green lights but yellow light is steady. tv is black and remote not responding
Jan 12, 2017 | Televison & Video
I have a sharp aquos tv model lc-32m400x. When i turn the power on via button at the back the green light comes on for about 10secs then turns to red and flashes about every 11/2 - 2secs. Any ideas.
Jan 11, 2017 | Sharp Televison & Video
Insignia NS-51P680A12 TV won't turn on. I have a blinking light that I am sure is a trouble code, but I can't find the codes anywhere online.
Jan 09, 2017 | Insignia Televison & Video
I have a lg tv 60 inch tv ln5600 when powering on red stand by light blinks 3 time then no light pic or sound not backlight and no image when using flashlight treid replacing power board does same
Jan 08, 2017 | LG Televison & Video
My sony wega kf-50E200A tv keeps turning off. during each cycle the green light blinks 42 times and the tv comes on again for about 3 minutes and it happens all over again
More than likely the power supply is defective, but without testing and the repair manual that is just a guess, you make the decision to replace or repair the TV.
Jan 07, 2017 | Sony KF-50E200A TV Lamp with Housing
Mitsubishi WS-65869 65" Rear Projection Television Logo
1,170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
