Question about Zebra LP 2844 Thermal Printer
TLP 2844 - red and orange solid light
i am new to zebra users, it was working for a day but suddenly orange light became on and it is no more ok. i checked label roll and ribbon, everything seems ok. pressing the feed button, it push the label very short, not in full length. ligh sometimes get red even, anyway it is not flashing.
please if you can assist....
  • Anonymous Jan 15, 2009
    same problem
5 Suggested Answers
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
SOURCE: Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Posted on Jan 21, 2008
SOURCE: trouble printing using Zebra TLP 2844-z
Does the tlp2844 come with a ribbon
Posted on Apr 08, 2008
  • 185 Answers
SOURCE: Zebra TLP 2844 Desktop Printer
The printer driver should be set to Continuous or it will think it is still Gap or Black Mark. Please adjust accordingly
Posted on Dec 20, 2009
Everytime I turn my Zebra TLP 2844-Z printer on,
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, click paper output and enter the size.
Oct 01, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Unable to upgrade Zebra TLP 2844-Z printers firmware
What is the problem if this works?
May be there is a problem on the boot rom!
Jun 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
Jun 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 2844 printer green light turns Immediately orange
Clean the "cover open sensor"
location: open printer, it's at the right hand side of printer, beside the green edge guide adjust thumbwheel, in line with edge guides.
Mar 27, 2009 | Zebra TLP 2844-Z Thermal Label Printer
One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
These 2 links will help you troubleshoot the problem:
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844
TLP2844 does not support Line mode.
but the LP2844 does.
If you neeed to use line mode change your printer. from TLP2844 to LP2844.
I had this issue last week.
Jan 20, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Light is red and not green
There may be several causes to this problem.
1/ The lid of the printer needs to be firmly shut before the Red light changes to Green.
2/ If the ribbon has come to the end then the red light will come on, change the ribbon.
3/ If you have changed label size and not recalibrated the printer to the label then the RED will come on.
Any error within the printer will bring the RED light on.
You can download the 2844 User Manual from
http://www.lancerlabels.co.uk/2844user.pdf
Jan 16, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra tlp 2844 trouble
Verify that the ribbon fits into position, back and forth. You can also calibrate the label by pressing the button while powering up the printer and release the button.
Aug 02, 2008 | Zebra R2844-Z Label Printer
Solid red light after flashing firmware
These are the 3 things listed as being wrong for the status light being solid red:
1. Media is out. Reload a new supply. Press feed button to
continue.
2. Power-up failure. Switch power OFF then back ON.
3. Printer ready to receive flash programming during
firmware download.
There's a programming manual available for download on Zebra's website: https://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
It might help.
Feb 15, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
382 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
