Can anyone help me locate the fuse panel on a 2001 FORD Taurus that controls the radio and CD Player?
Do you have a owners manual? this will show the location and the purpose of each fuse and relay. the radio fuse should be red in color and be located in the fuse panel on the drivers side it is a 15 amp and is red in color... hope this helps you...please rate this thanks
I found mine upper first row if you go from left to right the fuse should be an blue 15
There are owners manual for free online for the 2001
The fuse panel is located below and to the left of the steering wheel by
the brake pedal. Remove the panel cover to access the fuses.
To remove a fuse use the fuse puller tool provided on the fuse panel
cover. Fuse 27 is the ABS fuse
Thanks! We found out there was no fuse in there are at all. I just got the car and there was not an owners manual with it for some reason.I wish I could find one without paying the high price I seen online last night ($125).
Thank you for your help.
what number is the fuse location on 2001 ford taurus
I have a 1999 Taurus Owner Manual, but you can get one on ebay motors cheap for the exact year. Or, go to Helm Inc. for a new one.
does 2001 ford Taurus have a chip in the key
there is no fuse in the place were the owner guide say there should be one so i was wondering what do the transit relay do and should there be a fuse there
What radio station do u turn your radio on to turn on a trunk mounted cd player in a 1997 ford Taurus
98 ford Taurus CD cartridge won't stay in the CD player component
where is located
go to ford owners.com register then download your owners manual then go to roadside emergencies and you will find what you need
