Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Freezer cold but frosted up, Fridge Warm
We have model # 73503201...fridge is warm, compressor and inside fan not running, freezer is cold. I removed excess items from freezer since it was quite full and there was frost built up on rear wall/grille. Any ideas as to why my fridge is warm? I've been reading, on the net, that there may be a problem with the board, another idea was to pour warm water into the grille (????)....we're stumped. Thank You
  • 639 Answers
If the freezer is packed to the top and the air ducts are blocked it can not share the cold air with the refrigerator and it gets warm. If this is the problem, then the next day it should get cool again! let me know.
If you decide you need service!
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Sep 02, 2008
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Fridge is not cold and freezer is thawing all my frozen food , is compressor gone?
Check if fan in freezer is running as well as fan by the compressor and the compressor itself. Check for any frost buildup on evaporator cover in freezer.
Nov 17, 2011 | GE Refrigerators
My admiral fridge freezer has suddenly become warm. Freezer is defrosting and fridge is warm. Lights are still on so there is power.
Check your compressor area for lint buildup. Is the fan running down there?aa4623f.jpg Is the compressor running? Both should be running when the control is calling for cool and the inside fan is running. Looks for signs of distress associated with the compressor relay.7842c79.jpg4e4f405.jpg If all of that is good. Look for frost buildup on the freezer wall, a sure sign of a defrost problem. Remove the freezer service panel and look for frost buildup. You could have a bad heat or terminator.644d73c.jpg
Jun 27, 2010 | Refrigerators
Frig won't cool RM2652
You'll need to get in touch with the store you bought it from but Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 26, 2010 | Dometic RM2652 Refrigerator
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not cold
you have a fan motor and blade located between the fridge and freezer. What this fan does is regulates the temp of the fridge from the coldness of the freezer. If this fan is out the fridge will be warm. The fan is losacted in the space between the fridge and freezer on the inside near you temp control switch. Look at the top of the fridge on the inside and you will see a set of vents. The fan is located behind these slotted vents. Take care in removing the plastic cover and remove the motor. Take model and serial# to an appliance parts house for proper replacement.
Hope this helped you some
Dave
Jan 22, 2010 | Hotpoint HSS25GFP Side by Side...
Jcd 2389GT frig side by side does NOT appear to be getting cold. What could be wrong? Thermostat? Compressor? How can I test it? Fan for freezer is running but also appears to be generating cold air. Can...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM). Heavy frost indicates defrost problem.
Dec 01, 2009 | Refrigerators
I have a Model #GD5RHAXNB0 and the compressor keeps cycling. It is not cooling.
How to check stuff>
Aug 22, 2009 | Refrigerators
Freezer not freezing
Jul 11, 2009 | GE Refrigerators
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
220 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
