Question about Sigma SD9 Digital Camera
Battery Problem I was given an SD9 last month and so far like it except for some battery issues. Using fresh AA's it will often give me the 'low battery' warning as soon as they are loaded. I bought the CRV3's thinking that would solve it, it did initially, but after about 40 shots I took them out, tried some new AA's and again the low battery warning... replaced them with the CRV3's again, low battery (surely they were not run out after 40 shots?!) Everything is fine using power cable... but then it's not portable. Anyone have any suggestions?
    Sergeant:
  • 255 Answers
You need to begin using rechargeable batteries immediately. Look for nickle metal hydride (NiMH) cells that are at least 1800 mah and preferrably more than 2000 mah. Get two sets and a charger. Print this and take it with you. You can buy these at any electronics store. You'll need to charge the batteries before you can use them. And they don't really give you full life until they've been charged and discharged a couple of times. In other words, the first few times, you'll get a shorter life cycle before they run down. But you should see a marked improvement almost immediately.
Posted on Sep 13, 2005
Battery failure
I know this is almost a year old, but why can't you access the batteries? How have you been using the headphones without either recharging or simple using regular batteries? The batteries that came with the unit are not proprietary and any pair of AA batteries will work. I haven't used the Sony batteries that came with the headphone for years, won't recharge anymore. I have been using Sanyo eneloop AA rechargeable batteries ever since and keep a fresh pair of batteries recharged at all times. And it seems like they go on for ever, but the time between replacing the batteries is about once a month.
Feb 07, 2014 | Sony MDR-IF5000 Headphones
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
Jun 27, 2011 | Armitron Now Collection Crystal Accented...
I get no power when using fresh AA batteries or charged (Ni-MH batteries). Camera works fine when using AC power adapter.
Please make sure that you're using the LR6 AA sized batteries and also the terminals of the batteries are correctly inserted. Also make sure that the terminals of the battery compartment is clean without any obstacles or dirt. Also, try power reset and check if it helps.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If the issue persists, try the factory resetting. SETUP MENU-->RESET ALL--> OK
This should resolve the issue.
Thanks for using FixYa.
Jun 06, 2011 | Fuji FinePix 3800 Digital Camera
My Sigma SD9 rapidly drains battery power; and I don't mean over a short period of time, but over a few minutes. Regardless of new or fresh rechargeable batteries, the drainage is frustratingly...
For any camera, you need high power re-chargeable batteries - 2300 mAh or 2500 mAh. Try with a set of those. I have heard Eneloop suggested, but have no experience myself.
May 21, 2017 | Sigma SD9 Digital Camera
I got this camera a few years ago for Christmas and unfortunatley it is the worst camera I've ever had as far as battery life. I can take 2 or 3 pictures and then it shows low battery. I've replaced new...
It seems there is some where inside the camera leakage.. Are you using Li-ion rechargeable batteries or AA batteries For previously cameras, always comes with AA batteries, and most of the battery are with low capacity.
Jan 08, 2011 | Canon PowerShot A540 Digital Camera
With fresh batterys after a few shots camera shows low battery and auto shuts down
i am afraid u are using a low mAh rating battery. u have not mentioned the type of battery ur using. most digital cameras will use batteries with at least 700mAh rating. if it is AA size battery use 1300mAh rating or more if u want to capture videos as well.
Mar 12, 2010 | Canon PowerShot A1100 IS Digital Camera
Goes through batteries very quickly....often reading "low battery".
run a pencil eraser over the battery contacts on the camera, it works most of the time
Sep 07, 2009 | Samsung Digimax 530 Digital Camera
Powershot SX100is battery life
hey, i had same problem.. after i started using energizer ultimate lithium AA it started lasting weeks
Jun 16, 2009 | Canon PowerShot SX100 IS Digital Camera
Technical problem
I purchased a *ist DS used a couple of weeks ago, and it turns out to have similar problems. This camera seems very fussy about batteries. I am using rechargeable NiMh AAs. After about 30-40 exposures, the camera shows battery depleted. If I turn the camera off, then back on, it will show a charge - sometimes a full charge and will work for another 20 or so exposures. It can keep this up for a couple of days.
I read an explanation in one of the photo blogs (can't remember which) that suggested this was caused by one or two incompletely charged batteries in set of 4. If one is discharged the current from the others supposedly will flow to it, giving fluctuating power readings to the power management curcuit. This sounded plausible enough that I purchased a new charger yesterday which monitors the charge on each battery. Too early to tell whether this solved the problem or not. The other option is to switch to disposable batteries.
Oct 09, 2006 | Pentax *ist DS Digital Camera
Sigma SD9 Digital Camera Logo
151 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Doberman
Inky Fingers
Inky Fingers
Are you a Sigma Camera Expert? Answer questions, earn points and help others
