My Polariod camera was working fine, then i took the last picture and it just immediatly shut down. I tried turning it on again but nothing happened except the green light kept flashin with the camera lense still out. I waited a couple more days and tried again, the screen was still black and nothing happened. The camera isn't mine it's my aunts. I need to fix it fast before my aunt sees it! Please Help!!!!
Perhaps you have an empty battery?
Just remove the battery and try charging it on an external charger. When it is charged, try again. The camera should start with retracting the lens. Perhaps you again should power down and remove the battery for a few seconds after that, but just try it.
Switching of a camera causes it to start again, like a cold boot from a computer.
Monitor your battery, because if the camera shuts down very soon after that, perhaps you need a new battery?
Same thing happened to me a while ago. I was in a panic. I turned it on and off several times...no change. Finally, I turned the camera to the off position, took the battery out of the camera for about 30 seconds and put it back in again and it worked fine. No problem since.
TIPS: 1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery 2.) Remove front plate (screw driver may be needed) 3.) Check all gears, make sure they are correctly fitted in place) 4.) Move the gear manually to make the lens come out. 5.) keep it out, put the front plate back together. 6.) reinsert the battery, turn it on.
or... 1.) Remove the battery. 2.) Wait about 6-8 hours. 3.) Reinsert the battery.
or... 1.) Remove the battery. 2.) Try hooking it up through AC adapter, put correct voltage. 3.) Try turning it on. 4.) Remove AC adapter, reinsert battery. 5.) Turn it on. If nothing happens just tell me..
It turns out that the problem was the batteries. I put some good ones that I had in the camera and it started working just fine. Even though the others were showing that they at least partially working, maybe just not enough juice to really work. Anyway, with just about any problem - try new batteries first and see if there is any change or improvement.
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
WOW: All three Solutions Work Fine. I Removed the 6 small bolts and took the camera apart. lifted the tape and cleaned the contacts u;nder the tape with alcohol, let them dry then replaced the tape, lineing up the contacts on the tape with the ones on the body of the camera. Put the camera back together and put back the 6 bolts, inserted the batteries and presto: the camera worked. Thanks for the info , it really worked. Wes Reed
i just got mine today, and the batteries were dead withtin a couple of hours, so yes.
mines has decided to go black, it was fun while it lasted,, theres £90 ill never see again
