Question about Panasonic NN-S962 Microwave Oven
Will not heat
Panasonic microwave oven will not heat up. turntable works, but the timer will run for about 30 second, and stop. Not sure of the model
  • Panasonic Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
yysrsj
Posted on Sep 30, 2010
Panasonic NN-S563 no heat
hmmm...well..did you do a power setting? that is what is needed in the sequence just stated..try one of the presets like popcorn, to see if that works.
Oct 19, 2008 | Panasonic NN-S563 Microwave Oven
Microwave stops mid cycle
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Dec 27, 2012 | Panasonic NN-T664SF Microwave Oven
Panasonic microwave model #NN-SD697S stopped working. Timer works for 2-3 seconds without motor running(heating) then turns off. Push start button, nothing happens.
@William Miller - where are you located if i'm interested in your help with the microwave repair? I'm having the similar issue with the Start buton not working for my Panasonic NNSD697SS. Thanks
Feb 10, 2011 | Panasonic Microwave Ovens
Heating ceases after one second
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
May 30, 2010 | Panasonic NN-H275 Microwave Oven
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
NN-T990SA Panasonic Microwave Stopped Heating
This model uses an inverter to produce high voltage instead of a convential transformer system. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Dec 21, 2006 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-S962 Microwave Oven Logo
240 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
