Question about Sharp Televison & Video
On my modle 32u-s508b t.v. the channel keeps changing to input 2 and back again sometimes rapidly sometimes it will be stable for hours.
  • 2,071 Answers
ONE: First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.
TWO: If the reset does not help, try disconnecting anything on input 2. For example, if you have a dvd player connected to that input, the tv may be sensing its presence and switch over to it. (Especially, if the device is left ON.)
THREE: It is possible the controller IC is defective and is wandering around (electronically speaking). In this case, the set would need to be seen by a tech who can get inside and test the circuitry that controls the function switching. Lugging a big set like this into a shop is not easy, but is will save you lots of money compared to having them come to your home.
Let me know if you need more....
Hope this may help;
Regards,
VOTIT
Posted on Sep 02, 2008
    Brigadier General:
  • 6,966 Answers
Pls check if any of the buttons on the front panel control, more specifically the Source/Video/Tuner button is stuck in the pressed position. Alternately, check the same with the remote. You could also try removing the remote's battery to observe if problem persist.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
I presed RETUR buuton and now my tv doesn't show anything, only inscription - no signal. what should I do, to get back channels?
The input changed, ensure to look at the input, video, or channel three selection to determine which one was accidently changed. Once you fix this problem, you will be able to see channels again. It happens to me almost every day with the same unit!!! Sometimes turning power off then back on will fix the problem.
Jan 12, 2011 | BenQ PB6100-REMOTE
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
Tv Keeps on changing input.
remove the fuse and test it,if its burnt replace it with the same rating.
Jul 26, 2009 | Televison & Video
I cannot find the specs or user manual on the JVC archived items list. A few sites want to charge $10.00 for the user guide info, but I think that is too much to charge.
Defiantely not 200 watts
KS-A82
  • 2 Channel Amplifier
  • Bridgeable 2 channel amplifier
  • Output power: 25W x 2, 20 - 40,000 hz at .08 THD
  • 2 ohm stable
  • Adjustable gain (.1 - 2v)
  • MOS-FET DC-DC converter
  • Multi phase connection
  • 1 Pair of line input terminals
  • Remote relay turn on system
  • MSRP: $159.95
http://www.admtechusa.com/JVC.html#KS-A82
May 22, 2009 | Car Audio & Video
Channel switches on it's own
This is probably a sticking button, similar IR signal from another remote control, or simply a short on the system board that holds the controls.  A simple cleaning might take care of this.
Oct 19, 2007 | Sharp 32U-F810 32" TV
Automatic channel changing
1 either your remote button has pressed or some dust in contact. 2 dust near front panel buttons. 3 problem in sytem control section. 4 memory ic .
Sep 18, 2007 | Sharp 32U-F810 32" TV
MTX 502 2 chanel amp Pre amp problem?
Unless your amp is 1 (one) ohm stable then you may have fried it. When you attach a 2 ohm load across a bridged amp then you have effectivly placed each output channel on a 1 ohm load. Not a good thing in most cases. Try hooking up ONE speaker on one channel and one input to that one channel one at a time. Then switch the speaker/input to the other channel and see if you can get either or both channels to work independently. Needless to say you must turn the amp off before you make ANY change in the wiring.
Jun 25, 2007 | MTX Thunder 2-Channel Amplifier 502 Car...
Sharp tv changing channels
Well, the only thing that seems to be working so far is to plug AV cables into the "input 2" ports (on the front of TV). I plugged in my PS2, without turning it on. It has not switched at random since (about 30 minutes - it had been switching off and on for the past 2 hours). Anyone else have similar success?
Oct 28, 2006 | Sharp 32F540 32" TV
Televison & Video Logo
74 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
