The TV is acting like it has no power , but other applinacies are going great out of the same wall socket.
    Sergeant:
  • 293 Answers
Again this is a common problem that comes about when handling televisions. Check to make sure that the power cord isn't loose and that there is no damage. Try the tv with different wall outlets (even if other appliances work with the one you are trying to use as the TV might be drawing too much power or need more power than that circuit can handle) make sure that you are actually turning the unit on. Try changing channels volume etc. If nothing above works I'd suspect you have damage to the power supply of the television.
Posted on Sep 02, 2008
HOW DO YOU FACTORY RESET WESTINGHOUSE TV MODEL NO. DWM 48F1Y1
I had the same problem...turned out it wasnt the TV at all. It was actually the wall socket. Seems I had to many things plugged into one wall supply. (i.e. xbox 360, wii, audio reciever, dvd player, vcr, etc...) after switching some other items to a different socket my TV works GREAT!! I hope your problem is this ...
Jan 13, 2018 | Westinghouse Televison & Video
Scrambled screen
Hi, this could be a power issue, are you using a USB port on the TV to power the Chromecast?
Some older USB ports might not have enough power capacity in which case you should use the small power adaptor that came with your Chromecast and power it from a wall socket.
Hope this helps!
Feb 02, 2014 | Google Chromecast
37pfl7662d 05
Just do a hard reset to your set, and check. Unplug the TV from AC mains wall socket, and re-plug it back after some time, say about 25 minutes or so. This must make it a hard reset. For more information go to http://electronicshelponline.blogspot.com/
Dec 04, 2013 | Televison & Video
Tv takes a few minutes to turn on, why is that... the picture is great and everything else works fine
Almost all tv's have an "always on" circuit. You must be cutting off the power from the wall (A\C). Do you have the TV connected to ON\OFF POWER SWITCH that you TURN OFF when TV is not in use.? Connect the A\C plug directly to wall socket.
Aug 26, 2011 | Samsung TXJ2566 TV
Washer won't turn on at times. It acts like it has no power. Unplugging electric cord from wall socket and reconnecting seems to reset the unit and it functions normally for a while. After an hour or...
Try this first, unplug the unit and connect it to a different outlet and see if it corrects the problem. If it still continues, you will need to replace the control board. Good luck.
Jun 18, 2011 | LG WM2301HW Front Load Washer
Samsung 3D PN58C8000YFXZA. The standard power cable for this TV does not fit into a resesed wall power socket. Is there an alternative cable I can use
You could try plugging a power bar into the wall socket, then plugging the tv into one of the power bar sockets.
Feb 04, 2011 | Samsung PN-58A650 Plasma TV
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
One day just would not turn on, fuse maybe?
Possibly. However, I would try rebooting the unit first. Unplug the TV from the power supply for about 5 minutes. Then reconnect and try to turn the unit on. If it still does not work, plug a lamp into the wall socket where you have the TV plugged into. If the lamp lights, then you're getting power to the wall socket. If you have the TV plugged into one of those "power strips" check that it is turned on. If so, plug the TV directly into the wall socket. If it comes on, then you have a bad power strip. If the TV still does not come on, you'll probably need repair service.
Dec 01, 2009 | iLO 3200 32 in. LCD Television
Toshiba 57H81 57" TV Power
I have a toshiba 55hx70 same problem,repair guy just left said it was the power supply and wasnt worth fixing 350 to 400 dollars The tv is 9 years old and they wouldnt even take it to shop. Its been a great tv firs thing to go wrong.. Wo nder if I could replace it myself???
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
FPA LOCK IS ON HOW DO I TURN IT OFF?DONT HAVE REMOTE . HAVE A UNAVERSAL REMOTE
You will need an original remote I'm afraid. Cannot be done with a universal remote.
Jan 18, 2008 | RCA 20F420T 20" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
