Question about Fuji FinePix S5200 / S5600 Digital Camera
S5200 does not correct for light conditions anymore.
Not sure what happened, but my S5200 no longer automatically corrects for lighting conditions, regardless of what mode the camera is in. So now all the pictures come out very dark. Any Suggestions?
  • 34 Answers
You should reset to default the camera settings if you're not really sure what to change...but I thing the exposure has to do with the lighting conditions and also the picture mode(indoor, cloudy, night, sunny etc.) See if any of these will help you.
Posted on Sep 03, 2008
2006 buick allure , automatic low beams do not come on when key starts car
Headlamps
You can use the headlamps two different ways.
Place the headlamp switch in the HEAD position for normal operations
Place the headlamp switch in the OFF position for automatic lamp control (ALC) operation. During ALC the low beam headlamps are ON for daytime running lamp (DRL) operation in daylight conditions at reduced intensity or low beam headlamps ON at full intensity with exterior park lamps ON in low light conditions. The ambient light sensor is a light-sensitive transistor that varies its voltage signal to the body control module (BCM) in response to changes in the outside (ambient) light level. When the BCM receives this signal the BCM turns ON just the low beam headlamps at reduced intensity for the daytime running lamp (DRL) operation. A resistor wire is used (CKT312) to reduced the voltage which reduces the light intensity for the DRL's function. The ambient light sensor can also turn ON the low beam headlamps and the exterior lamps for automatic lamp control (ALC). Any function or condition that turns ON the headlamps will cancel the DRL operation (this means no reduced voltage to the low beam lights). Thirty seconds after you start the engine with the headlamp switch in the OFF position, the DRL will perform one of two actions:
Illuminate the low beam headlamps at reduced intensity in daylight conditions
Illuminate the low beam headlamps and exterior park lamps for low light conditions
The DRL operates when the ignition switch is in the RUN position, the parking brake is not set and the transmission is not in the PARK position When these conditions are met and the DRL ambient light sensor indicates daylight conditions the DRL will illuminate
Should have BCM scanned for DTC'S - diagnostic trouble codes , could have DTC'S stored in memory !
DTC B2645 Ambient Light Circuit
The body control module (BCM) monitors the ambient light sensor signal circuit in order to determine if the daytime running lights (DRL) or the auto headlights (ALC) should be turned ON in the AUTO mode. When the BCM senses the ambient light sensor voltage is between 1.75-4.9 volts, either the DRL will be commanded ON or the ALC will be commanded ON.
  1. Turn ON the headlamps.
  2. Ensure that the headlamp dimmer switch is in the LOW position.
Do both low beam headlamps illuminate?
Is only one low beam headlamp inoperative? YES / NO
IF no
  1. Disconnect the lamps switch assembly.
  2. Install a jumper between the headlamp switch headlamps ON signal circuit and ground.
Do the low beam headlamps illuminate?
Go to Step 18
Go to Step 7
7
  1. Remove the headlamp module.
  2. Install a fused jumper between battery positive voltage and the switched low beam voltage supply circuit.
Go to Step 8
Go to Step 11
8
Test for the following in the headlamp module control circuit:
An open
A poor connection
A short to ground
Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step 19
Go to Step 10
9
Inspect for a poor connection at the harness connector of the lamp switch assembly. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 19
Go to Step 14
10
Inspect for a poor connection at the headlamp module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 19
Go to Step 15
11
Test for a short to ground in the low beam voltage supply circuit. Refer to Circuit Testing and Wiring Repairs .
Go to Step 19
Go to Step 12
12
Inspect for a poor connection at the harness connector of the underhood fuse block. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 19
Go to Step 17
13
Inspect the inoperative low beam headlamp voltage supply and ground circuit for a high resistance, a short to ground, or an open. Refer to Circuit Testing and Wiring Repairs .
Go to Step 19
Go to Step 16
14
Replace the lamp switch assembly. Refer to Headlamp Switch Replacement .
Did you complete the replacement?
Go to Step 19
15
Replace the headlamp module. Refer to Relay Replacement in Wiring Systems.
Go to Step 19
16
Replace the inoperative low beam headlamp. Refer to Headlamp Assembly or Headlamp Bulb Replacement .
Go to Step 19
17
Replace the underhood fuse block. Refer to Testing for Intermittent Conditions and Poor Connections .
Go to Step 19
18
Replace the BCM. Refer to Control Module References for replacement, setup, and programming.
Go to Step 19
19
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
IF
Sep 30, 2015 | Buick Cars & Trucks
Well nissan xterra 2000 v6 3.3 automatic. was dyin after warmed up. at stop lights. found that the tps was bad. changed it, set it. now when driving, not dying anymore. but when shifting into 2nd gear...
YES SOME YOU NEED TO ADJUST WITH A SCAN TOOL OR A VOLT METER REFER TO THE REPAIR MANUAL FOR THE SPECTS MAKE SURE THE LEVER ON THE TPS IS ON THE CORRECT PLACE SO IT CAN WORK CORRECTLY
Sep 23, 2013 | 2000 Nissan Xterra
My daughter left the lights on my 2000 honda accord. When I tried to jump start it there was no power...no lights, radio, not even a click. What could be the problem
Can you describe how you tried to jump start it? The correct procedure is: Turn off everything on the car that needs the power. With the donor car on connect the jumper cables, negative to negative (or a good ground away from the battery to avoid sparks), then the dead positive, to the good positive. let the donor car charge your battery for some time, maybe 10-20 minutes (depending on the condition of the battery). turn off the donor car, remove the cables. DO NOT try to start the dead car while the donor car is running (Most people screw this up, when the other car starts it adds too much voltage and current to the system and one or both cars seriously damages something- usually the alternator). Repeat the procedure for a longer time (up to 30 minutes) if the first go didn't work. If your car still won't start, and you followed the procedures correctly, then it's very possible your battery is too old (is it the original? If so, it's 13 years old and needs to be replaced for sure) or in bad condition and will no longer hold a charge. It's possible you blew all your fuses too, but check the battery condition and age first.
Aug 22, 2013 | 2000 Chrysler Sebring
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
My living air xl-15 prove it light does not come on anymore and it seems that the unit does not prodoce ozone. I tested the light in the normal postion set at 12:00 with the plate out but to no avail....
If you are sure that the plate is clean, in perfect condition, and inserted correctly, it would appear that the transformer is defective. This means that power is not going through the metal contact fingers into the plates.
The light probably has burned out. It is not essential to the working of the machine, so it isn't anything you need to be concerned about.
Vollara (formerly Alpine/EcoQuest) is no longer producing or servicing the XL-15. However, a newer version, called the Classic, is available. You can call Customer Service 800-989-2299 and they will tell you your options. Use #16618 if you need a referral number.
Jan 08, 2011 | Alpine Air XL-15 Air Purifier
The light switch functions correctly with the
I have exactly smae problem with my Clio, if you have the cure please email me at p@remmington.plus.com
Jan 16, 2010 | 2002 Renault Sportwagon
Hp f370 printer doesn't turn on
my hp f370 does not turn on anymore. checked the power supply adapter using a multimeter, the voltage are correct as per the label. when i press the ON button, nothing happens, not even a light will lit. what seems to be the problem?
thanks in advance.
Nov 10, 2009 | HP DeskJet F380 All-In-One Printer
Keeps cutting off after 30 miles
WE HAD THE SAME PROBLEM BUT NOT FOR LONG SO ITS BEEN WORKING FOR US AND HOPEFULLY THIS WILL WORK FOR YOU. WE'VE RECENTLY LEARNED BY JUST STARTING YOUR CAR THE CORRECT WAY IT HASN'T BEEN HAPPENING TO US ANYMORE AND THATS BY: WHEN YOU START YOUR CAR YOU ARE SUPPOSE TO HAVE YOUR FOOT ON THE BRAKES PUSHING LIGHTLY DOWN, THAT IS THE CORRECT WAY TO START A 1989 740 SERIES VOLVO QUOTED STRAIT FROM THE ORIGINAL MANUAL ON HOW TO OPERATE THE CAR. GOOD LUCK
Nov 06, 2008 | 1989 Volvo 740
Copier not functioing correctly
Try to referesh the copier, remove the USB cable then turn off it. Wait for 2 minutes turn it on and the plug the usb cable and then observe what will happen.
Jan 23, 2008 | Canon MultiPASS F80 All-In-One InkJet...
S5200 Focus range
I assume you're taking the mickey out of Fuji here. But just in case you're not it is obviously meant to describe the AF assist lamps range in low light conditions.
Aug 30, 2005 | Fuji FinePix F10 Digital Camera
Fuji FinePix S5200 / S5600 Digital Camera Logo
114 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
