I have a 50 inch tv that does not show the boarder of the screen, and when you press menu, or volume, there are two writings that come out in blue and pink. I dont know what is it, is the tv completely useless?
    Sergeant:
  • 293 Answers
Disconnect it from any inputs and then try to enter the menu. Sometimes peripherals like dvd players will activate built in settings for compatability. If it persists, try working with the menu anyways, it could be a malconfiguration that is fixable through correcting the picture options, color, and sharpness.
Though I have seen a similar problem occur on a smaller tv after a lightning surge hit it. The picture was fine but the menu, channel number etc, went off screen half way. If this is the case the tv is probably ok but the controller card is scrap and needs to be replaced. I'd contact the manufacturer if it needs to be replaced they maybe able to supply you with one.
Posted on Sep 02, 2008
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
We just got a 50 inch LCD PLCD 5092 8b plasma TV the only thing that shows is a blue screen with proscan on it how do we get it to play
hi if its a new tv press menu button or settings on the remote and look for tuning & follow instructions :::::: good luck
Jul 26, 2015 | Proscan Televison & Video
I have a panasonic viera 50 inch plazma tv and cannot get the volume to work. i hit some button on the remote and now no volume. i do not have manual and the remote is from att uverse
Do you have a little symbol on the screen showing a speaker crossed out? If so you have pressed the 'mute' button. another press of the same button should un-mute it.
Jul 17, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Mitsubishi 50 real projection blue screen
Turners are Bad Signal Board Call Encompass Parts 1-800-638-3328 or your nearest Repair Shop.
Dec 31, 2009 | Televison & Video
My Toshiba 50 inch projection screen TV isnt displaying
If you are capable of some basic troubleshooting you can determine what's wrong but you won't likely be able to fix it yourself. If you remove the TV's back panel, you can locate three plug connectors for the convergence correction yokes. You pull the red, blue, and green connectors and then plug the TV back in and hit the power button. If the TV comes on, its a failure of the convergence output ICs and will cost $350-450 if you call in a service company.
michtech
Feb 14, 2009 | Toshiba TP50G60 50" Rear Projection...
I am on a dell xps m170 with a nvidia geforce 2 go 7800 card. I have connected it to a 1080p 40 inch Samsung lcd. How do I make it fill the screen on the TV I have a blue border all around the desktop. My...
go into your display properties and you may have to look around for a sec, but there is a setting in there that will say enable boarder uncheck this and you will no longer have the boarder around the screen
Dec 11, 2008 | Dell nVIDIA GeForce Go 7800 GTX, (256 MB)...
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Black screen
I work at at a school, and we had the same problem. Turns out, it a Closed Captioning problem.
We found the manual, and it states that "If a large black box covers 80% of your screen, the Text mode is probably set. Press 'Closed Caption' to turn it off." The "Closed Caption" button is on the remote. If you don't have the remote (as in our case), you can go to "Closed Caption" in the menu, and pick something like C4 and T4. That stopped the black box for us.
Jun 09, 2008 | Televison & Video
Tv PROBLEM
The black box your are seeing on the screen is the box to display text. It is listed under your "cc" closed captioning setting as T1, T2 etc. Go into your closed captioning and shut off the text. You can still leave closed captioning on or off. The text system was never really used but they put it on all of the TV's.
Feb 05, 2008 | JVC AV-27D303 27" TV
Televison & Video Logo
Top Televison & Video Experts
