Question about Dell Axim X5 Pocket PC
SD memory...is there a limitation for the Axim?
I was wondering if there was a limitation to the size of SD memory for the Axim? I recently bought a 256 MB memory stick...and I know they go up to 1 GB now...
I do not believe it is the Axim itself, it's the OS. WM 2003 can use 2 gig cards. Any OS under that cannot. WM 2002 can only support up to 1 gig SD cards. Those are the only two that I have tested.
Posted on Jun 13, 2007
    Master:
  • 852 Answers
The limitation is only what is available. Currently, the biggest SD card you can easily get would be a 512mb, though the 1gb's are on the way.
Posted on Sep 13, 2005
SOURCE:
Axim x5 sd not reading
I would think it is having more trouble with the adapter than the actual card. It could also be the storage size of the card that is the problem as well. Try a regular 2GB SD Card and see if it works. If it does, then it is probably just the adapter.
Jan 01, 2009 | Dell Axim X5 Pocket PC
Coolpix 5200 + 4GB SD card
Any size SD card will work. The capacity limit is with the card, not the camera. All the camera does is serve as a recorder/reader for the card.
Mar 04, 2008 | Nikon Coolpix 5200 Digital Camera
Size of sd card
Hey there harad82, many digital cameras have difficulty formatting and thus difficulty recognising larger size memory cards. This limitation is due to the date of design of the camera, and the only recent availability of the larger memory cards. Also the processor power onboard many cameras is quite limited and cannot handle too much information, such as when one of these cards begins to fill. This can result in lost data. I would suggest you try one before purchasing, perhaps a friend can help with a loner or you can check your cameras specs for limitations on card size. The smaller size cards (512mb or less) rarely cause these difficulties. If you need help with specs please respond with your camera make and model#. Good Luck!
Feb 25, 2008 | Vivitar ViviCam 5299 Digital Camera
SD memory card limit?
The A430 works with MMC and SD cards. Your 4GB card is actually an SDHC card and will not work with this camera. You need to use SD cards, which max out at 2GB.
Dec 31, 2007 | Canon PowerShot A430 Digital Camera
Dell axim x30
HI You have two ways: 1) Install the ActiveSync (Version 4.2 is recommended) PC Software with your PC first Next, you connect your Axim to your PC. Then you install the software or game into your PC. it will also install into your Axim automatically thru Sync process. 2) Or install the software or games into your External SD Memory card thru USB SD Card reader. Then put your sd memory card into your Axim and run the software or game. The 2GB or 4GB SD Card is reccommended since the game or software sometime is huge. I hope it is help. Regards, pingping
Jun 14, 2007 | Dell Axim X30 Pocket PC
Speed of CF vs SD in Axim
The reason CF COULD be faster is that it is a parallel connection (16bit IIRC) while SD/MMC is serial in nature. Now, assuming the INTERFACE were the limiting factor in the speed this could become significant. Unfortunately the interface is NOT the limit (in most cases), the limit is the actual fetching of data from the memory itself. Being Flash it is nowhere near as fast as some of the other types of memory we are used to. It is especially slow when being written to. Newer cards out there are faster then older ones, but in the end I doubt you would notice much if any difference between the speed of a CF versus an SD/MMC card
Sep 14, 2005 | Dell Axim X5 Pocket PC
Help : Can I access Memorysticks on AXIM
Since a SD memory card is about the same size [width and thickness] as a Memory Stick, I doubt there will ever be an adapter available between these two formats. There just isn't any room unless they came up with a very large adapter which would stick out and be unwieldly. You can get Compact Flash adapters (which are much larger) from a company called Pretec for about US$59.00, plus I'm sure there are others. I use a full sized PC Card adapter on my laptop to convert between the SD Memory card for my Axim X5 and the SmartMedia card for my digital camera and MP3 player.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Can I use 256M in Axim
Not sure about the SD but I don't see why not, as for CF I'm positive it'll support ANY size cf card out there...
SD/MMC Compatibility?
I'm not sure that this will be a once a for all answer, but the link below says that any device with an sd slot can handle mmc but devices with slots designed exclusively for MMC cannot handle SD. Since the axim has an SD slot, I would say that it is compatible with MMC although I haven't tried an MMC card and the manual doesn't specific mention MMC memory.
Dell Axim X5 Pocket PC Logo
128 people viewed this question
Clive
Clive
Alun Cox
