Yamaha rxv-992 receiver wont power up
Hi, my yamaha receiver power on just a split second then no power. I made sure the impedence selector switch was set exactly and tried again. no luck .. any ideas?
    Problem Solver:
  • 17 Answers
Disconnect all your speakers from the receiver. Turn the power on, and see if it stays on. If the unit shuts off with all the speakers disconnected, then you most likely have a faulty unit, and it will need to be repaired or replaced.
If the unit stays on with all the speakers disconnected, then you most likely have a bad speaker or a bad connection with the speaker wire.
Starting with one speaker, hook it up, and turn the unit on, and again see if the unit stays on, or if it shuts off. Do this until the unit shuts off when you connect a speaker.
Then disconnect all the other speakers, and leave the suspect speaker attached. Again, try to power up the unit. If it fails with that speaker attached, but works when it is not attached, then that speaker is your problem.
Posted on Dec 09, 2008
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
I want to hook two speakers (4ohm each) on rxv-671 on both L/R side. what is the best option to do that either parallel or serial? Also plz describe the method if any.
The best method is - DON'T. When you hook more than one speaker up to a single speaker output, it drops the impedance that the receiver sees and you risk blowing the amp. If you need to hook more than one up, do so through a speaker switch box. It will match the impedance correctly so the amp doesn't get damaged.
Sep 22, 2013 | Yamaha RX-V671
Hi, I have a Yamaha RXV 459. Have speakers of DSE. The speakers are of 8 impedance. Was listening to music till 4 hrs ago. Switched off the whole unit from the power source. Returned and the unit is...
Disconnect the speaker one at a time, you may have a shorted voice coil, the message was indicated a short in the speaker wiring. If no joy then you may have burned out the power transistors.
May 16, 2017 | Yamaha RX-V459 Receiver
Just bought a used yamaha receiver model RXv793 do not know how to hook it up.
First do not panic by seeing all sockets in the back side of the receiver.You can connect 5 speakers and one subwoofer on the speaker A switch and maybe a second pair of stereo speakers on the B switch.All the speaker sockets have red and black terminals, so do all speakers. Just get decent cables ( You can buy a whole connection Kit if you want ) and connect the corresponding outlets to you speakers.If you have a powered subwoofer connect the subwoofer input to a socket labeled Subwoofer pre out on the RXV. You will need a RCA to RCA cable for that Next you will need a coaxial or Optic fiber cable to connect a DVD player digitally. The back of the DVD player will have a socket marked coaxial out, and so does the RXV's backside. Just link them .
Turn on the system everything should work. If you are not getting DVD sound there is small button on the RXV front panel called Digital input -- set it to auto ( keep pressing the button and it will scroll through various modes). Also remember to switch on speaker A on the front panel.
Mar 09, 2011 | Yamaha RX-V793
Speaker impedance and the Yamaha RXV 463
You risk to crash a set of speakers. In any case this will have a detrimental effect on the sound
Aug 04, 2008 | Yamaha RX-V659 Receiver
VOLTAGE SELECTOR
Not if it wasn't manufactured for an area of use that is running something other than 120 volts. If it wasn't imported then plug it in and go.
May 03, 2008 | Yamaha RXV-350 Receiver
AX1 wont power-up.
Hello amos78
First, perform a visual inspection at the back of the unit and verify that speaker wires are not loose or shorting out with another connection. Find the impedance selector switch and verify that it is set to the proper position according to your speakers' impedance. It has to be all the way up or down, never in the middle. (Warning: Do not move the impedance selector while the receiver is powered. Make sure power is OFF on in standby, otherwise receiver will be damaged). Try power ON.
If these actions do not cure the problem, disconnect all speakers and try power ON again.
If the unit powers on, it is possible that one or more of your speakers or wires are damaged.
If none of the above actions fixes the problem, it is very possible that the receiver's internal circuitry is damaged.
Hope this helps you. Let me know.
cancerags
Dec 27, 2007 | Yamaha DSP-AX1 10-Channel Amplifier
Yamaha RX-V595A tuns off automatically
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
Oct 27, 2007 | Yamaha RX-V595A Receiver
253 people viewed this question
 Grubhead
Grubhead
