Question about Pentax Optio S Digital Camera
Problems with the LCD monitor
I have an OPTIO S, the LCD monitor failed... Playing back the pictures works fine, it displays the menus as usual, but I can't take new pictures anymore, the LCD appears BLACK (like if it were off) and when I shot, the picture also looks black. I resetted the settings, but didn't work. Any help with this??? Thanks a lot.
  • mulbs Dec 12, 2007
    I have an Optio 555 with an identical problem, I can display exisiting pictures, and the LCD screen shows the "welcome" screen and menus perfectly, but if I do not get any image when lining up a shot (just the positioning arrows on a black screen). The camera thinks it takes a photo - it displays a black image in a slideshow for example but I'd like to take pictures a little more interesting than just black rectangles!
  • cinnamon1 Apr 23, 2008
    I have an Kodak CX7330, with exactly the same probelem as your Optio. the LCD monitor failed... Playing back the pictures works fine, it displays the menus as usual, but I can't take new pictures anymore, the LCD appears BLACK (like if it were off) and when I shot, the picture also looks black.
Se callo y el monitor se rompio
Posted on Dec 28, 2007
    Novelist:
  • 196 Answers
You've probably got something as simple as a ribbon cable loose in the camera. Beware though, dismantling is a serious task unless you have experience. Amazingly the CCD is often connected in such a simple, analog-esqe, way that disconnecting it doesn't cause an error, just a black screen.
Posted on Feb 15, 2006
SOURCE:
Vertical stripes on digital camera lcd
The fact that it takes the pictures ok confirms that it's not the ccd which has failed.
If the menus on the lcd screen are also distorted then it confirms that the lcd screen itself is faulty and this is replaceable. If the menus display just fine, then it's the internal circuit board which has a problem and replacing that is not normally viable.
Either way, the Samsung s860 is a budget model available for as little as £60 new, so even the most minor repair will cost more than replacing the camera: unless it's still under warranty (one year from purchase date) it's definitely uneconomic to repair. Samsung themselves wouldn't normally bother; a warranty claim usually means they chuck your camera away and send you a replacement.
If you're in the UK click here for details of how to proceed with Samsung.
I hope that I've helped, if so please remember to rate my answer.
Feb 19, 2010 | Pentax Optio 60 Digital Camera
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
Monitor shows picture for 1/2 second then goes black, 22" display. also will not show display menus. have hooked another monitor up and works fine. also have hooked up to another computor and problem...
When you switch the monitors, do you still use the very same vga cable? If you don't, then it's time to change the monitor. When it turns on and off inmediately it means that it's receiving the signal, but that's it. If it's brand new, exchange it.
Sep 01, 2009 | X2Gen MW22U Monitor
My Hanns-G HC194D LCD Monitor Takes Forever to come on
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 16, 2009 | Samsung SyncMaster 203B LCD Monitor
LED BLACKED OUT
Could be a problem with the CCD circuitry. You will need to get it serviced, I'm afraid.
Jun 19, 2008 | Pentax Optio S5i Digital Camera
BLANK SCREEN
was she playing with the keyboard. ??
She/he may have shut off the monitor from the keyboard. look for a little picture of the monitor.
Sometimes you need to hit fn (function) key and the display key to toggle it on
Robert
May 08, 2008 | Sceptre S1902D-4 Monitor
Optio 33LF LCD problem
This often indicates a card error. Transfer all your images then format the card in the camera. If you still have the problem, try a different card. If you still have the problem then looks like you will have to send it in for repair.
Sep 08, 2005 | Pentax Optio 33LF Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Pentax Optio S Digital Camera Logo
107 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
