Question about HP Photosmart D7360 All-In-One InkJet Printer
Ink system failure
HP Photosmart D7360 but not all in-one only printer. Just stoped working one day with this message, Ink system failure 0xc05d1281. Do everything it says to do. Turn off, take out cartridges replace, turn back on. No go with anything. Also keeps coming up with the message turn off with on button not power point but I do and it still growles at me. About had enough. No solutions at HP web site.
  • 2 more comments
  • Hetzner_M Sep 07, 2008
    Ink system failure. Turned on and off. Unplugged and plugged back in.
    Removed ink cartridges and put back again. ALL of them have 1/3 or more full of Ink.
    there is no paper jam. The printer has worked well for
    about a year. Out of the blue ...this just started
    happening. I cannot find any way to get it corrected. Any
    ideas ?
    THe printer is a HP D7360
  • mygirls08 Oct 01, 2008
    ink system failure
  • Anonymous Dec 20, 2008
    I have the same problem
  • snapdragonsu Dec 29, 2008
    same as the other. just stopped printing - gave us the error #0xc05d1281 and tells us to turn off at with on button and not wall and took all ink cartridges out and put them in again then turned on and it is now going through the preparation for ink and now we just got the same message.
    This is being a real pain.
I had this problem, and after hours spent trying to get the covers off, I got the right side off and found two white ribbon cables. One had come unplugged. Fixed! Still got a paper feed problem though.
Posted on Mar 30, 2009
Ink failure
Posted on Feb 17, 2009
    President:
  • 4,402 Answers
Have you unpluged it from the outlet? can you see any paper stuck?
otherwise you have a bad system board and would cost more to fix than just to by a new one.
Posted on Sep 03, 2008
there is no paper jam. The printer has worked well for about a year. Out of the blue ...this just started happening. I cannot find any way to get it corrected. Any ideas ?
Posted on Oct 09, 2008
Photosmart 7360-ink Ink System Failure error
1) Press * and # at the same time
2) Press 1, 2, 3 and “support R0632M” should display
3) Press > and “information menu” should display
4) Press > and “configuration menu” should display
5) Press OK and “hardware failure status” should display
6) Press OK “failure status: clear”. Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, and plug cord back in then turn printer back on.
And Thanks.
Mar 11, 2010 | Office Equipment & Supplies
How do you take the right side off a HP D7360?
Follow the steps below to resolve this issue.
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.If the error codes still display on the front panel, service the printer.
Dec 29, 2009 | HP Photosmart D7360 All-In-One InkJet...
How to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
Aug 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Dec 04, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart D7360 All-In-One InkJet Printer Logo
877 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
